Question about Braun Health & Beauty
On May 17th I bought an Oral B type 3757 toothbrush from Argos. I exchanged it this morning for a new one as the original brush would not accept a charge. I know that as the brush would not run when I switched it on. When a charger is working it usually gets warm or even hot. Although the charger was plugged into a power socket for most of yesterday it did not re-charge the toothbrush's battery and the charger did not get warm. The new brush is sitting on the new charger and the charger is plugged into a power socket. So far the charger remains cold after about 2 hours on-charge time. How do I know if the charger is working as there is no indicator light or any other apparent means of showing that charging is in progress? There is some power in the brush's battery which shows it has been supplied to me at least part charged to me as it runs when switched on.
  • 35 Answers
SOURCE: Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Posted on Dec 31, 2008
  • 10406 Answers
SOURCE: HP6720s run slow when plugged in??
Start -> Control Panel -> Power Options
Ensure that when plugged-in, it is set to "Maximum Performance".
Posted on Apr 27, 2009
  • 7 Answers
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
  • 18 Answers
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Posted on Sep 04, 2009
SOURCE: packard bell netbook nav50 battery stopped charging properly. bought a new charger and battery and it still wont charge it up.
LOL, I didn't know Packard Bell was still making computers. I would think they sold you a bad battery. I've purchased new batteries before that would not charge.
Posted on Apr 05, 2012
I recently bought some replacement Oral B replacement brush heads. They are the wrong ones. I need the Oral B compatible replacement Brush heads. Can I exchange please. Barb Foster.
Depends where you bought from. If you take the electric brush and the unsuitable items to the store, you will convenience them that you are genuine. A good store will be helpful.
Aug 23, 2013 | GPS
Brush wont spin
Check whether your brush is still in warranty. Either way take it to an oral-B certified shop for fixing as there's no point paying to have it fixed by someone who doesn't really know what they are doing.
Good luck
Feb 17, 2013 | Oral B CrossAction Power Replacement Brush...
Do electric toothbrushes require a different amount of toothpaste compared than manual toothbrushes?
No, you should put the same amount of toothpaste on all types of toothbrushes. You should put enough so you can clean your teeth well.
Feb 04, 2013 | Health & Beauty
What are the best electric toothbrushes available?
The best electric toothbrushes are the Oral-b Professional Care and the Phillip Sonicare Diamond Clean. You can find more information on these electric toothbrushes on their respected websites: http://www.usa.philips.com/c/diamondclean/289711/cat/en/ and http://www.oralb.com/products/professional-care-smart-series-4000/.
Electric rechargeable braun toothbrush 500
I had the same problem at the beginning of the year. I think i had bought 3 electric tooth brushes and all seemed to cave in within a couple of weeks. My friend recommended going to Macy's to buy one, which I did and it is still going strong. Maybe you charged it for a very long period of time and it overheat the system circuit? I'm not sure but I would recommend getting a new toothbrush.
Jul 04, 2012 | Oral B Braun B Professional Care 500...
Oral-B 12V charger?
I am looking for exact the same as this. Braun should make a 12-volt charger to their tooth brushes. It shouldnt be too complicated and very well possible as the battery in the handle is only below 6 volts.....!
Feb 17, 2012 | Oral B Braun Oral b 3d Excel, Pro Care &...
Is there or what is the max charging time for a oral B 3757 toothbrush
you can change your battery and service for a worker of electornic
Aug 16, 2011 | Braun Health & Beauty
My 5000 series tooth brush will not charge i tried it with a few adapters and still no result could it be the base or plug that is malfuntioning , i am an electrician and there is power in the socket so...
I have bought many rechargeable devices and about 4-5% of them have bad Chinese batteries in them. I also have converted nearly all battery operated items to rechargeables and these often have spotty performance with several out of a couple of dozen not worth keeping. You might try running the batteries down as far as possible and then trying to recharge. If they are NiCads, they may have developed 'memory,' a known weakness of that type and NiMh batteries in particular seem to need several charge/discharge cycles before they will come somewhat up to their rated capacities.
Mar 24, 2011 | Oral B ??? Oral b Professional Care...
Need instructions for changing head on oral b brush. cross action power
you simply remove your old head brush, put a little ring (usually rings come separately and are different colors) an your new one and put it on the handle - it will hold.
Dec 29, 2010 | Oral B 2 Replacement Toothbrush Heads...
My Braun Oral-B Sonic Complete Toothbrush wont hold a charge
I had the same problem today. I use the charging plug which has the "wrench" remove the bottom screw...I was attempting to remove the battery to reset the brush. I could not get the bottom of the brush off as I did not want to use a screw driver or similar to pry it off in case I needed to return the brush.
So I was trying to pull the bottom off and my finger was on the on/off switch, as I was wiggling the bottom of the brush to try to dislodge the battery it started working.
The brush seems to have a reset button on the back but that did not do anything. The display also has moisture trapped inside it, which I am sure is not good!
Any way try this and maybe the battery will come out and I am sure that will reset the brush...if not maybe you will get lucky as I did and wiggling it will work. BTW, this is with the Oral-B Triumph Professionla Care 9000
Apr 21, 2008 | Computers & Internet
Health & Beauty Logo
301 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
