Question about Fujitsu Heating & Cooling
I have a Fujitsu ASY7ASCCW indoor unit coupled with a AOY7ASCC outdoor unit.The problem is both units do not work with each other,I have jury rigged both items,and both work perfectly,but wont work coupled together,as they once did.Help is needed,with thanks
  • Walter Kunesky
    Walter Kunesky May 29, 2011
    I dont know where you got these numbers but I can not find anything on either of the numbers on their website. What country are you in?
SOURCE: NEED SERVICE MANUAL FOR FUJITSU SPLIT SYSTEM
try, http://www.uelements.com/downloads/Fj-aby14rga-sm.pdf
Posted on Jan 07, 2009
notsomot
  • 67 Answers
SOURCE: Fujitsu AOT30PMAL inverter outdoor unit not working
Sounds like your compressor is seized or a start fault. If the unit is under five years old it should be under warranty. Call Fujitsu warranty out to have a look at it for you.
Contact details as follows
http://www.fujitsugeneral.com.au/contact.php
Sorry but either way I think your going to need a part there is very little that I can do unless your in WA.
Hope this helps
Posted on Jan 11, 2009
  • 14 Answers
SOURCE: System will not start up.
This is a signal fault between the indoor and outdoor first make sure the dip switches are set start with the unit closest to the condensor set as unit 1 then next unit as 2 and so on the dip switches are inside the indoor unit on the pc board if you check the manual it will tell you which swithes to set, if this wasnt done when the units where installed they would have never worked i would also check the signal wiring between the wallmount and the splitter box / bc box and make sure there isnt a loose connection when you have ruled this out id say more than likely it is a faulty indoor board on the wallmounted unt
Posted on Apr 08, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
  • 21 Answers
SOURCE: split unit, I get heat but no cold
Unit will not run unless both indoor fan coils are in cool mode.
Posted on May 22, 2009
Fujitsu ASTA12LCC WILL NOT HEAT OR COOL. GREEN TIMER LIGHT FLASHES TWICE AT INTERVALS. FAN WORKING. IS IT REPAIRABLE?
Serial signal reverse error. Basically the outdoor unit is not talking to the indoor unit. This is normally due to damage to the outdoor controller PCB and it needs to be replaced.
Jul 03, 2017 | Fujitsu Heating & Cooling
Fujitsu a/c outdoor model number AOTG12LVC indoor unit economy light flashing continuously, operation light single flash, timer light single flash this sequence repeats
Serial communication error. This means that the indoor unit is not communicating with the outdoor unit usually because the outdoor unit is faulty. You can check the indoor unit by switching it to 'fan' mode and seeing if all functions work normally (fan speed, louvers move as directed). If it responds normally, then it's probably ok so you can turn your attention to the outdoor unit. A common problem with the outdoor controllers is that they are susceptible to bugs, geckos, etc. shorting them out which will mean replacement of the board.
Mar 05, 2017 | Fujitsu Heating & Cooling
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
Outdoor unit fan always runs even when indoor unit is off. I have disconnected all control wires from the headunit (at the outdoor end to rule out faulty signalling). The fan runs all the time, with just...
I have had this problem with a Fujitsu unit before. If the power is supplied to the outdoor unit first but unit is meant to have power supplied to indoor unit first, outdoor will only stop when power is cut off! In that case, you will have to run the power cable to the indoor unit first and then connect from appropriate terminal back to outdoor unit. (Often the indoor will stop outdoor unit by just cutting the power to it via use of a relay on the pcb.)
Jan 16, 2010 | Panasonic Heating & Cooling
I have an intermatic T101 and the trip pin broke off. Can I replace the tripper or do I have to buy an new unit?
You may be able to rig it up. They dont sell parts for these. If you can jury rig it just get a new one
Sep 12, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Jun 01, 2009 | Fujitsu Heating & Cooling
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Jan 27, 2009 | Fujitsu 24C1 Air Conditioner
Fujitsu split level
Check for errors like blinking indoor light if present. Reset the error by disconnecting power supply from the unit for 10 sec. and "on" the unit. If the error persist, some parts of the unit may be defective and need to replace. Like room air thermistor, coil thermistor in the indoor side or the relay board. Some safety device in the outdoor may give in, some outdoor parts may be defective. You need a qualified technician for the this problem.
May 17, 2008 | Fujitsu 24C1 Air Conditioner
Fujitsu general ars40 duct type
you have to clean your A/C unit, indoor and outdoor, be sure all frost are de frosted before you run your unit again, or else it will frost again. if this not work your unit need re-gassing.
Jan 20, 2008 | Fujitsu 24R1 Air Conditioner
Heating & Cooling Logo
302 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
