Question about Watches
How do I stop a "Pod 100M" watch from beeping on the hour please?
  • 710 Answers
Hi ie48,
Can't find a manual on this watch, but will try to give you some things to try.
If you have a mode button on your watch, press this button in until you see the alarm time. Once you are in the alarm mode, press either the reset or start. On mine, I have a picture of a bell that will go off the screen when I turn it off. Others will say "ALARM" OR "ALM". When the pic/words disappear, then it should be off.
Other digital watches use a combination of buttons that must be pressed at the same time to get into the alarm mode. Once you see the alarm time, follow the above procedure to turn it off. I don't know how many buttons you have, but try pushing two at a time to get to the alarm mode.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on May 30, 2011
I purchased one Seiko Sports 100M watch from Noida in Feb and from day one it is not functioning properly. The watch stops in 8- 10 hours even after a continuous use of 12-14 hours. I have given the watch...
Take it back to the dealer and insist that he takes it back and gives you either a refund or a replacement.
It is clearly faulty and it is his liability to put is right.
Apr 14, 2011 | Seiko Watches
My watch beeps every hour.
Yes, you can. Go to the settings mode, push the pushbutton till you see the small blinking icon. Repeat to push the button till the icon disappears.
Rate me, please.
Jul 30, 2009 | Watches
Diesel DZ7076 beeps every hour
Press all the buttons at the same time. It's so annoying...
Jul 22, 2009 | Diesel Audio Diesel Watch
Installing a spring in the Timex Ironman WR 100M watch
That spring is called COIL SPRING and it transmits the signal from the microprocessor to audio membrane fixed to caseback. This is how you hear all the beeps, alarms, e.t.c.
Examine watch movement and you should fine small hole (it can be even marked with an arrow and writing: COIL SPRING).
Fit that coil spring in to the hole and close the caseback. If you hear no sound, you fitted it in the wrong hole, so, refit the coil spring till you find the right hole and hear the beeps.
Rate, please.
Mar 30, 2009 | Timex Sports Ironman Triathlon 50-Lap...
Beeping watch
When in the 'TIME' mode, Press the button top-right of the face - the bell should disappear, and the hourly beep, and the buttonpress beep.
Jim
Mar 13, 2009 | Nike Imara Run WR0075-014 Wrist Watch
Can't shut off beep going off every hour
Hold down all four buttons to reset the watch. My time didn't reset but the beeping FINALLY stopped.
Mar 01, 2009 | Casio G-Shock G510D-1AV Wrist Watch
How do i make my watch beep by the hour
Press and hold SET, then press START/STOP. This should turn the chime on. Press it again to turn on the alarm.
Dec 27, 2008 | Timex 1440 Nylon watch
Nike watch
In TIME mode - not ALARM - top right hand button marked "START/LAP" toggles hourly beep on/off. As not in ALARM menu, easy to put on unintentionally.
Nov 07, 2008 | Casio DW290 1V Classic Alarm Chronograph...
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Watches Logo
42 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
