Hi. My name is Martin Linear read test failed (E-CD-005 I have a problem with recording on disc. Please for help
Palmbeach
  • 185 Answers
SOURCE: DMR E55-P will not read DVD-R
Hi Benyto
Thank you for the information. Sorry that you are having such problems.
Nearly all the problems on ths DMR E55 are due to a faulty power board. The greatest load on the power supply is when the unit first reads discs and also when finalizing. Sometimes the unit cannot read discs and sometimes it continuously self checks.
Try replacing IC001 on the power board. This is a 5 pin regulator #STRG6353. This component gets very hot and the heatsink is poor. When I replace these, I use a larger heatsink and some heatsink paste which helps to prolong the life of the component. If you look at the regulator, you will see by the colour of the circuit board that it gets very hot. It fails after two or three years in all DMR E55s.
Be careful when you take the old regulator out because the print can lift away from the circuit board.
I have posted full instructions on how to replace the STRG6353 >HERE<
Hope this helps
Posted on Mar 03, 2008
  • 8 Answers
SOURCE: DVD player/ recorder problems... PLEASE HELP!!!
I have now had two Panasonic recorders 3 years apart and both have gone down with this same fault.
It's a shame as they are a fantastic recorder, I would have thought Panasonic would have put this right by now. It now 5 years on since I bought my first one and it sounds as if they still have the same fault.
Why the hell can't they just fit a standard computer dvd drive that’s cheap to replace, and not this abortion they fit.
I was looking on E-bay for Panasonic recorders that where faulty and found around twenty.
ALL WITH THE SAME FAULT
"DVD drive faulty"
I’m now looking for a new one but don’t know what to do as I have a ton of discs that need to be finalized, may just forget about them and keep clear of Panasonic in future.
Posted on Jul 09, 2008
  • 4 Answers
SOURCE: Lite-On LVW-1105HC won't record, often fails to read disc.
Judging from product reviews it seems that this is a fairly unreliable unit. About the only thing you can do to possibly improve performance is to clean the laser lense. There are commercially available cleaners for CD/DVD players. The best way to clean the lense is to disassemble the unit and use a cotton swab with alcohol. This may be difficult for someone who doesn't have experience disassembling electronic devices.
Posted on Dec 31, 2008
SOURCE: wont record on blank pc disks!
I just ran into the same issue- 9 times out of 10 it's the disc- you have to be VERY CAREFUL when buying discs tthat say CDR or CD-RW but they have to say AUDIO or MUSIC on the packet - remember there are diuffernt linds of blank discs out there and they all do different jobs- read the above again to be clear
Posted on Aug 08, 2010
  • 3 Answers
SOURCE: Hi, my car today failed
the code is not for engine, it is transmission code, to tell exactly you need a SAAB Tech 2 scaner, It may be the neutralsafety switch . 29 differnt codes for trans. try to move shifter from park to 1. 20 times it may help for now,reset code drive car to set all redines codes, Neutral safety switch is on back order from saab.
Posted on Feb 15, 2012
Recording
The No OPC message means that the unit can't record. The laser power calibration for the burner failed the internal test with that disc. Was the disc a blank disc? Make sure that you use a clean CD-R or unfinalized CD-RW. Try a different lot or brand of CD-Rs or CD-RWs. If the problem persists, then the laser on the recorder is damaged. If the unit is under warranty, contact Philips. However, based on the date given on the manual, this may not be worth finding a shop to fix the unit. DVD/CD burners for computers are fairly cheap but I'm not sure of the specs for a replacement CD burner for inside this unit.
The manual is available from Philips here: www.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_eng.pdf . The trouble-shooting information is on page 21 (page 23 of the PDF).
I hope this helps.
Jul 11, 2013 | Philips CDR765 2-Disc CD Recorder
Hi.I have CD Recorder Marantz DR6000.After reading and initalizing blank CD-R Audio next on display show OPC ERROR.It,s reading all audio CD,s,oryginal,and CD-R.When I wanna finalized old CD-R,recorded by...
DR-6000 only accepts CD-R audio or CD-R music discs, not the standard CD-R discs. the difference is that the audio and music discs have the OPC formatted differently and they cost a bit more because they include the royalties fee. Standard CD-R discs won't work in this recorder. The correct discs have compact disc "digital audio" logo on them.
Oct 01, 2010 | Marantz DR-6000 CD Player
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
I have this recorder and when I go to burn a cd,
Always 1/3? Try just playing a full CD through it to see if it can smoothly accesss the whole disc in a linear fashion just like a recording would do. Might be something physical if it has problems at the same relative positions recording and playing. Otherwise, ther're really no reason an electronic failure should care where on the disc it fails.
Jan 28, 2010 | Philips CDR785 3-Disc CD Recorder
I have the uv8 phase linear and burnt cds wont play only store b
I had the same problem - its because when you burn the disc, you don't use up all the recording time; and the read light on the player is so sensative that if there is any unused time, it will not accept the disc. So, make sure your recording time exceeds the disc space, and make sure the last song you burn is not your favorite because it will cut off midway through the song.
Jul 02, 2009 | Phase Linear UDV9010 Car DVD Player
Unit failed to read any discs
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its says no read.
Jun 20, 2008 | Panasonic DMR-ES25 DVD Recorder
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
Apr 04, 2008 | Philips CDR796 2-Disc CD Recorder
NO RECORD
This message usually indicates that a non-audio disc is in the record tray. Please use only blank music CD-R or CD-RW media. Refer to page 12 of the owners manual for more information regarding acceptable media type for the DA-3826. Also, the laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a CD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 07, 2005 | TDK DA-3826 2-Disc CD Recorder
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
