Primary hard disk drive 1 not found secondary hard disk drive not found
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
Posted on May 30, 2011
Diskettedrive 1 seek failure primary hard disk drive 1 not found secondary hardisk drive 1 not found cp says strike f1 but cp boot only up to xp logo then re start again and so on again and again
If both of the hard drives are on the same data cable/disk drive controller it is unlikely that both the have failed. Reseat the data cable connectors on the hard drives and at the motherboard.
Reboot you computer and hopefully it will boot up.
Check the BIOS configuration to see if the BIOS detects the hard drives.
If not the disk drive controller on the motherboard may be faulty.
Aug 26, 2011 | Dell OptiPlex GX150 PC Desktop
My Dell Opt, Plex GX 260 reads "Primary hard disk 1 not found, and secondary hard disk 2 not found" ? please help?
You can reseat both cables for both hard drives, however its sounds like the mother board is bad.
Oct 20, 2010 | Dell OptiPlex GX260 PC Desktop
It will come on but it says primary hard disk drive 0 found and secondary hard disk drive 1 not found
  • Hi, there are (3) three areas that you can search to find: Hard Disk Drives. 1. From the Desktop, click on the Computer Icon to open the "Hard Drives (window)," next find the Hard Disk Drive (1), this is the "Primary" (C:) Drive. 2. Next, in the Devices with Removable Storage (1)below is the "Secondary" Drive, this will be the (CD or DVD Drives (D:), for "External Drives" the drives locations will be (E: or F:). 3. "If the CD, or DVD Drive is present in this area?" Right click to open, select the Properties "icon" the window opens; in the "All disk drives" (block), select, and "highlight" the CD or DVD Drive, next click on the Propertie's button below! 4. In the Device Status (block), see: if the device is "working properly?" Next, click on the Drives button, select to "Update Drivers." Note: The computer screen may "blink' (3-5 times), this means the update has taken place, Click on the "Apply and OK buttons, to finish. "You may be ask to "Restart the computer, if not? Restart the computer." *The "Second" area is the "All Programs" in the Start Menu, scroll to find: Media Disk Player. Select to open, click on "Setup, and Install." Follow all instruction carefully! *The "Third" area is in the Control Panel from the Start Menu; find in the (right pane). Open the "Contol Panel" go to, and select Hardware and Sound, in the next window, click to open the Device Manager; scroll to find: DVD/CD-ROM drives. Click to open; do the same as above instructions, step by step. "Did this solution help? If so, Helpful Ratings Feedback is appreciated, thanks paul7of9"
Feb 15, 2010 | Dell OptiPlex GX110 PC Desktop
Primary IDE port does not work. My main hard disk drive and DVD writer drive are connected to the Secondary IDE port. If I move them to the the Primary IDE port, both the drives do not get detected at all....
Good day sir, there are several way to connect an extra IDE if the motherboard is full:
  1. Buy a PCI to IDE/SATA card. Check your local computer dealer if there is available.
  2. Buy an external USB to IDE Hard disk enclosure.
Of course, these are things to buy, but check first the CMOS setup if the Primary IDE is enabled on your PC.
Oct 12, 2009 | Intel D865GVHZ Motherboard
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Hard Disk failure
Try to run CHKDSK from command prompt, and if that doesnt work, its probably corrupt / hard to recover
Apr 21, 2009 | Dell Dimension 2400 PC Desktop
2 primary ides 2 secondary ides
Ok.... The Primary IDE Should be configured so that your Primary Hard Drive is Set To Master (the jumper pins must be set to the same, each drive has a guide on top or back, or it's written above or below the jumper pins on the back of the drive.
Primary = Hard Disk 0 (Your Main Hard Drive)...This one is to be set as Master and plugged to the END of the IDE Cable....Another Hard Disk / Drive can be connected as Slave (sometimes Cable Select Will Work depending on the motherboard). Remember The Jumper pins on the Drives!
Secondary= One drive must be set as Master, The other as Slave.
That Should do it.
Go into your bios setup screen, go to the boot configuration and set it up so that your boot order goes as follows:
1. Floppy Disc Drive
or........
1. Optical Drive (cd or dvd)
2. Hard Disc 0 (this will be named whatever your Hard drive model number is)
3. Hard Disc 1 (this is the second hard drive, if you want it to be bootable, it's your choice, if not, then set it up to boot off your secondary optical drive,
Make Sure that under IDE devices menu, everything is detected correctly.
Now Save Settings and Exit.
That should do it
Apr 21, 2009 | Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Computers & Internet Logo
David Payne
David Payne
