Question about Dishwashers
Hello my beko de6340s has stoped working midway through a cycle there is no light we have checked the fuse and thats fine but theres no power?
  • 4,323 Answers
Hi
Please take off the lower access panel and clean the drain pump assembly completely, if the issue returns then you'll have to replace the timer/control. Hope this helps...please post back for further assistance.
Daniel
Posted on May 29, 2011
Hi, I have a Beko DE6340 which just stopped working. No lights or anything and have changed the fuse to no avail. Someone suggested cleaning the drainage pump completely but would that cause it to not
With all dishwashers when you press knob or push button, they first start to empty out any remaining water. If yours isn't doing this it could be that your pump has clogged, or has died altogether. So at the point your at the answer is yes. Check all the lines to and from your pump to discharge. GOOD LUCK FRIEND.
Dec 02, 2014 | Beko Dishwashers
What might cause a flashing PF code midway through a cycle? Circuit breaker is fine. Any advice greatly appreciated.
Stop trying to restart it! There is obviously a fault so check your manual. If not in there contact Manufacturer or service agent.
Aug 10, 2014 | Frigidaire Dishwashers
No functions at all on my 7244e there is power and water to the machine just wondering if there is a fuse machine has been working fine but just stopped midway thru a cycle top wiring looks...
If there is power to the PCB and there is no action on the customer control , then there is possibility that the processor board is faulty You might need to take a voltage check to see if the processor gets the regulated voltage, if there is voltage to processor without any action the mP can be faulty and you might havve to replace the board.
Sep 18, 2010 | Whirlpool Washing Machines
The standby light wont come on when i press the button and the plug fuse is fine and it was working about 2 hours ago any suggestions?
Check the power outlet with other devices,Change the A/C power cord.All that fail ur power board is gone,must be rebuild by changing parts or buy a new board.
Sep 17, 2009 | Beko 324250WN 28" TV
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
When powered on protection light comes on
Protection usually means that there is a short some where. If it is inside the amp or external I couldn't tell you. You could check the fuse to make sure that isn't blown. I had a Memphis amp that blew both fuses and the protection light came on. I swapped out the fuses and worked fine, still works. If you have a multimeter set it to OHMs and check the resistance between the power terminals. It should be very high. If these things don't work then there is most likely something wrong with the amp or your power termination. I wasn't able to find a lot of information on this amp but if it has screw type terminals, did you use terminals. If you just put the wires in the terminals make sure there wasn't loose strands touching. I hope you can get this one.
-Andrew Hawkins
Mar 27, 2008 | Car Audio & Video
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool GH7145XF
Check your main breaker fuse in your panel/subpanel.
Otherwise if the inline fuse is good and the main power is good, then look at the power supply for the microwave.
Mike
Nov 09, 2007 | Whirlpool GH7145XF Microwave Oven
Kitchenaid dishwasher just quit mid cycle?
Check your thermal fuse. The fuse is located inside the control panel on or near the main control board. It will be a bullet shaped component mounted with a white plastic clip with two wires leading from it. The fuse should read a short if good. Now...keep in mind, if the fuse blew it is usually for a reason. Replacing it may or may not correct your problem. In some model dishwashers there was a thermal fuse kit that was required to be installed which involved cutting the wires and using a wire splice to connect the new fuse. It seems that there was a design flaw where the gauge wire used in manufacturing would cause the thermal fuse to blow prematurely due the wire overheating. I can't remember if this applies to KitchenAid, but I believe it does. You may inquire about this at your local parts store. I hope this helps you.
Aug 15, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
Owen Barnes
