Question about HTC Touch HD Smartphone
Stuck on the screen align window,i have tried but i cannot exit
If you don't have problem to shut down it and restart do this. start your phone after sometime.
Posted on May 29, 2011
I can't exit safe mode in windows xp
Click on Start button, choose option. Or remove power.
Nov 02, 2012 | Computers & Internet
Garmin iQue M3. Gradually not responding to touch
First make sure the screen is clean of any dirt or oils that may deposit on your screen from your fingers. Use a stylist (a mini pencil like item that came with your GPS) or and other non metal semi pointed item and go through the screen alignment process. Hit the "X's" as you see them (it will move 4 or 5 times to ensure the screen is aligned.) After it is aligned it should give you other options. I have seen GPS's recycle trough the alignment process two or three times before cycling out. If you do this and you are still you are having issues, and you have tried resetting it, you may have a hardware issue.
Mar 07, 2011 | Garmin iQue M3 Pocket PC GPS Receiver
My htc tytn ii stays on align screen after hard reset what should i do help me please
Have you completed the alignment procedure? The phone will not let you progress until alignment is complete.
Once complete, click "OK" in the top right corner to exit the screen.
If this has fixed your problem then please take a moment to rate my answer, if not then please give more detail about what's happening and I'll try to assist you further. I don't have your exact model, but have owned a few other HTC models using both Windows Mobile (like yours) and Android operating systems so I'm confident that if the problem has a fix I can help you to find it..
Mar 24, 2010 | HTC TyTN II Smartphone
Samsung sch-i760 hard reset. will not exit align screen
I had a very similar problem with an HP PDA and it turned out that the screen was bad. Try another hard reset and see if it fixes the problem. If Not then the screen went bad. Foxpaw13
Jun 12, 2009 | Samsung SCH-i760 Smartphone
Palm treo smartphone upon reboot gets stuck on "align screen"
yes u cant exit the screen until u do the align test for the touch screen its a easy fix on the back of the phone on the left side top there is a hidden pen that comes out of the phone and when u get the pen out use the point of the pen to touch the center of the circle on the align screen test it will ask u to do this in every corner of the screen after that the phone should get out of the align screen test and be able to work good luck
May 29, 2009 | Palm Treo 755p Smartphone
My i-mate pocket pc screen does not get aligned
Hi. You should tap the screen with the stylus carefully and with a little bit more pressure, accurately on the cross sign evertime it appears. When you successfully tap each cross sign once, you would be able to pass to the other settings, but in case there is a problem passing though the screen aligning, here is a small tutorial about how to bypass that screen through your PC: (http://goatechno.blogspot.com/2008/12/windows-mobile-stuck-at-screen.html) Hope this helps.
May 27, 2009 | i-mate Pocket PC
Touch Screen does not Working. The case is ok
Touch panel is faulty if u are stuck in the first alignment screen try getting it replaced under warranty
Feb 01, 2009 | HTC Touch Cruise Smartphone
Imate jam on aalign screen
how can exit from align screen of imate
Jan 09, 2009 | Computers & Internet
Align screen
i have the same problem wat to do i am stuck wit align..
Aug 13, 2008 | i-mate PDAL Pocket PC
HTC Touch HD Smartphone Logo
213 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
