Question about Bostik Hot Melt Glue Guns Adhesives
I have somehow realeased the trigger so it is not pushing the glue forward but i cant seem to open the glue gun up 2 fix this problem?
    Champion:
    New Friend:
  • 217 Answers
There should be small screws near the handle so that you can split the casing into 2 halves. then look for the spring that regulates the trigger
Posted on Feb 26, 2013
Trigger is sticken
Glue guns are made mostly out of plastic, and are really not made to be repaired.
May 10, 2015 | Crafts & Hobbies
My 3M scotch-Weld AE II Glue gun drips
There isn't much you can do with that. The trigger may not be fully returning to an open position when you release it; try pulling the trigger slightly (in the opposite direction from what you pull when extruding glue).
I usually keep a paper plate underneath my glue gun because it always drips.
May 14, 2014 | Crafts & Hobbies
Need the instruction manual for a Stanley GR100 glue gun
I do not believe there is a manual. there are instructions on the package. Insert the glue stick and turn on the gun. When the glue melts and the trigger moves glue will come out the front tip. This model has 2 temperatures so if it delivers too fast or runny you can lower the temperature. You pull the trigger to push the glue stick into the heating element to melt the glue. It is pretty straight forward. As the glue stick is consumed you stick in another glue stick. I suggest testing on something before using on your project. Do be careful of the hot end. It will definitely burn you if you touch it and the glue coming out is nearly as hot as the metal.
Jan 17, 2014 | Stanley Gr100 Glue-pro Dualmelt Glue Gun
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
How does a glue gun work?
A hot glue gun is a very useful tool for joining modelling materials and even more substantial materials can be fixed together with it. 'Sticks' of solid glue are pushed into the back of the gun, the trigger is pressed pushing the glue stick forward and molten glue comes out of the nozzle. The glue is manufactured from thermoplastics.
You can check out this site for more info:
Jan 10, 2013 | Crafts & Hobbies
Hi, can't get Stanley dual melt glue gun to
some users have complained that the trigger fails. when this happens, the glue will not heat up. if it seems to be a problem with the trigger and the gun is relatively new, i would try to return it and get a new one or get your money back
Nov 13, 2012 | Crafts & Hobbies
Arrow TR 550 heats up fine but glue stick won't feed by the trigger. If I push the stick with my hand glue does come out, but the trigger seems to "slip" on the glue stick. Any ideas?
The trigger probably really is slipping on the glue stick. If you've changed the type or size of glue recently, try changing back to what you were using, or just something else. Maybe the glue stick is too small, or too slippery for the gun. If not that, then it's a mechanical problem. There are some screws on the side of the gun. With it unplugged and cool, take them out and open the case. It might be stuck together with some internal connections as well as the screws, but jamming a flathead screwdriver in them can usually wedge them apart. With the gun open, move the trigger and look for the parts that move with it in the area where the glue stick goes. If you can find something to attach to these parts to make them just a tiny bit longer, do that. The parts that grip the glue have probably worn down or just don't fit, and the fact that you can tell the trigger is slipping means that it's probably very close to grabbing, but not quite close enough. Any little extension to the grabbing parts should do, but be careful not to block the path of the glue.
Feb 28, 2011 | Heavy Duty Arrow Pro Glue Gun Tr550
Dear Experts, I need assistance from you ppl.I stay in India. I bought a medium quality glue gun and a glue stick. I plugged the gun to the power socket(220v)and waited for the glue to come out of the...
It takes a couple of minutes for the gun to heat up. When you first plug it in, touch the metal nozzle with your hand. It should become obviously hot within 15 seconds and too hot to touch within a minute . After it fully heats up (a couple of minutes), squeezing the trigger should advance the glue stick and push molten glue out of the nozzle. However, there is often an initial resistance to the trigger and you may have to squeeze a bit hard to get it started. If there is a problem with the trigger mechanism, you can also advance the glue by pushing directly on the back end of the glue stick with your thumb. Good luck.
Aug 04, 2010 | Garden
Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Aug 27, 2008 | Rubbermaid Power Tool Hook Black
Bostik Hot Melt Glue Guns  Adhesives Logo
123 people viewed this question
Top BOSTIK Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a BOSTIK Craft and Hobby Expert? Answer questions, earn points and help others
