Question about Health & Beauty
How do I replace the battery on my philishave QT4040 beard trimmer
I cannot even find the screw, nowhere to be seen!!!
Posted on Aug 29, 2012
  • Peyu
    Peyu Jan 18, 2014
    Hi Alan, my philishave qt4040 battery is also dead and I want to replace it. After some hours, I find out how to open it. The first step is to remove all the thing you can normally remove (blades, deposit, etc). Then you have to separate the grey plastic part that covers the engine from the black one (use a small screwdriver to pry, there isn't any screw). Once this grey part is gone, you will be able to remove the ring that is used to adjust the cut size. Then you have to open the black part in 2, there are 6 points of union (3 on each side,there are 4 on each side of the ventilation, 2 close to the charger port). If you reach this point, congratulations ! you're done ! There you can change the battery, it's 2 AA 600mAh batteries, but they are welded.... I joined a picture of the different parts
  • Jan Andreas Knudsen Dec 17, 2014
    Thanks for the instructions and the image, Peyu! Do you have a larger version?
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Posted on Jan 15, 2010
SOURCE: Battery Replacement for Remington PG-300 Beard Trimmer
Hi
The manual will give you info on the battery that is inside the trimmer.If you can get to the battery then buy same TYPE or similar to the original---VOLTAGE/CURRENT RATING/CHARGING etc and size, connection
Hope this helps
Jay
Posted on Nov 17, 2007
brector3
  • 1610 Answers
SOURCE: can i get another battery for the remington mb-35
you will find replcement batteries at shaveroutlet.com
Posted on Jan 16, 2010
mcdevito75
  • 1970 Answers
SOURCE: HOW TO CHANGE A BATTERY IN EP 100 BRAUN BEARD
mcdevito75 here, You may or may not be able to change the battery--ies some batteries are attached to a circuit board. refer online to Braun.com Battery replacement and, you"ll most likely need special screwdriver to change the battery--ies.
Posted on Jun 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: changing trimmer heads on Conair Beard Trimmer - Model GMT188
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
How do i replace my philips beard trimmer battery?
It depends on what model you have. For Example, this is how you replace the battery on a Philips QG3020 beard trimmer:
Philips QG3020 Disassembly Change Battery
You can write here your trimmer model, in order to get instructions for that.
Jan 29, 2015 | Philips Health & Beauty
Battery not holding charge very long
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Apr 06, 2014 | Remington MB-300 Beard Trimmer
Back put together trimmer
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer, which includes how to reassemble it: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Dec 09, 2013 | Remington MB-300 Beard Trimmer
Remington mb300 battery replace how
The rechargable nickel-cadmium is hard-wired and not replaceable.
Instructions for removing the battery from the user manual:
1. Make sure your groomer is unplugged from any outlets so you don't risk an electric shock.
2. Remove side panels/grips
3. Remove the 4 housing screws
4. Pull or gently pry the clipper halves apart, exposing the batteries.
5. Remove batteries from the unit.
6. Twist batteries to break wires. Wires may also be cut.
I also own an MB-300. The battery still works good and I loved this trimmer but I need a new cutter blade for mine.
Jan 01, 2013 | Remington MB-300 Beard Trimmer
Change battery wahl 9918c
How to change the Battery in a beard trimmer - YouTube
? 3:38
https://www.youtube.com/watch?v=QlLqB9S5oaI
Oct 20, 2013 - Uploaded by Shake the Future
Do you have a beard trimmer/clippers that don't hold the charge? Time to change the battery and give your beard trimmer a second life. .... Wahl Trimmer All-In-One Lithium Ion Unboxing - TimmyTechTV - Duration: 6:32. by ...
Jul 28, 2012 | Wahl 9916-800 Groomsman Beard Trimmer
Need a replacement blade for ER240 beard trimmer in bangalore
panasonic WER961P replacement blades for beard trimmer panasonic er240 cutter replacement parts.
panasonic er240 replacement blades
Sep 06, 2011 | Panasonic ER 240 Beard Trimmer
NEED A REPLACEMENT BLADE FOR TRIMMER ER 240
May 12, 2011 | Panasonic ER 240 Beard Trimmer
Conair beard trimmer: took screw out and can't
Nov 11, 2009 | Conair Deluxe Rechargeable Beard &...
Hi
Hope this helps
Jay
Nov 17, 2007 | Remington Titanium Precision PG-300 Beard...
Health & Beauty Logo
656 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
