Question about Acer Aspire 5100 Notebook
How do i connect the wire from screen , on my acer 5100
Black screen
the Acer Aspire 5100 notebook has a VGA port which you can connect to any VGA monitor which will allow you to see what the laptop is trying to display allowing you to troubleshoot the issue.
-HTH.
Jan 19, 2014 | Acer Aspire 5100 Notebook
White screen but plugin monitor works. is it the screen?
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5100/Aspire5100sp2.shtml
http://www.laptopscreen.com/English/model/Acer/ASPIRE~5100/
So you PHYSICALLY checked the connection of the Video Cable, TO the motherboard, TO the screen Inverter, and TO the back of the LCD screen?
Visual inspection will NOT do. If either motherboard connector, or LCD screen connector is loose, the width of this letter -> I < you won't see it, and it will affect the video signal.
The Video Cable connects to the motherboard under the Middle Cover, above the F4 and F5 key on the Keyboard. (Left edge of F4 key over to middle of F5 key)
[Middle Cover is Acer speak for Switch Cover. The cover strip above the Keyboard, and below the LCD screen ]
aspire-3100-5100-5600-lcd-cable-dc020007o00-.html
http://www.laptops-we-r.com/prestashop/aspire-5100-parts/109-acer-
Click on the view to enlarge. Top left side connects to the LCD screen. Rectangular Black connector with thick round cable, at the bottom, connects to the motherboard. Small cable coming off at the bottom, connects to the screen Inverter ]
From the motherboard connector the Video Cable routes up under the left Hinge, and into the Display Assembly. It then connects to the screen Inverter, and LCD screen.
From normal opening, and closing of the laptop, repeatedly, the Video Cable may become pinched.
This can lead to loose connections.
It can also lead to damage of the Video Cable.
If the sheath of the cable shows apparent signs of damage, the tiny wires inside may be damaged also.
Stretched/Broken
This means to ENSURE that the Video Cable is NOT the problem, a continuity test needs to be performed on all of the Video Cable's wires. (OHMS)
If an economical multimeter ($5 to $12) is not available, suggestion is to take it down to the nearest 'Mom and Pop' computer store, and have them check it. Labor charge should only be a few bucks.
Video Cable checks out it's on to the screen Inverter, for the diagnoses.
[NOTE*
This diagnoses is for an Acer Aspire 5100 Notebook PC. Uses a single (1) CCFL for a Backlight, and has a screen Inverter. Laptops that use LED's for a Backlight generally do not use a screen Inverter]
Did you test the screen Inverter, or replace it?
http://www.amazon.com/Acer-Aspire-5100-Inverter-PK070005U00/dp/B005F1N5O2
http://www.fonerbooks.com/test.htm
NOTE*
Takes a sensitive multimeter. Read fairly expensive.
Primer;
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor. Suggest start out with your audio turned down ]
It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Acer Aspire 5100 Notebook PC uses a single (1) CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ ]
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer over.
If the screen Inverter is good, the LCD screen is bad.
Replace.
[The LCD screen, and the screen Inverter are a MATCHED unit.
When purchasing make sure you get the correct screen Inverter, or LCD screen ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 09, 2012 | Acer Aspire 5100 Notebook
Acer Aspire 5100
Sounds like the power jack is loose if you have to hold it in a certain position. As for the screen your inverter might be shot. Try connecting an external monitor to your laptop and see if you get a display.
Sep 08, 2009 | Acer Aspire 5100 Notebook
Update: Acer Aspire 5100 black screen post by daddysangelg.
yes, check first the inverter, then vga cable connection, or the video card...
Jun 07, 2009 | Acer Aspire 5100 Notebook
Acer notebook usb not recognized
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process. http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Jan 17, 2009 | Acer Aspire 5100 Notebook
Acer 5100 Has no screen
It sounds like the mainboard or CPU died. Generally the hard drive is fairly easy to remove, look on the bottom or the side for a screw labeled "HDD", which should uncover the hard drive area.
Feb 25, 2008 | Acer Aspire 5100 Notebook
My acer aspire 5100
hmmm...anything at all on screen?
Feb 18, 2008 | Acer Aspire 5100 Notebook
Input failure on the above laptop
just try to check your connection may be your usb connection is loss contact....or maybe the cable wire is disconnected...to solve that problem you just try another keyboard and mouse....
Dec 17, 2007 | Acer Aspire 5100 Notebook
Acer 5100, Lines throughout screen!!
connect to an external monitor, if it works fine then it is the monitor, if not its the video card.
Dec 11, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
