I HAVE NO DISK TO UP LOAD ON TO MY COMPUTER WHAT ELSE CAN I DO TO GET MT JUKEBOX ON MY COMPUTER
Why can't I get a home dvd to load to my MacBook Pro?
https://itunes.apple.com/gb/app/free-dvd-ripper/id625150797?mt=12
Feb 27, 2013 | Apple MacBook Pro Laptop Computer with...
I cant use Music Match jukebox on my new PC. Why?
  1. Verify that your music is in the MusicMatch Jukebox Plus folder on your hard drive. Double-click the "My Computer" icon on your desktop, or select "My Computer" from the Start menu. Open the C:\\ drive. Double-click "MusicMatch Jukebox." Review the folder to check that all of your MP3 files are inside the folder. If not, search your computer for the files and drag them to the MusicMatch folder.
  2. Turn on folder sharing to ensure the software can access your music files. Open "My Network Places" in the "My Computer" folder. Click "Properties." In the resulting window, click "File and Print Sharing." Check the box next to, "I want to be able to give others access to my files." Click "OK" and close all open windows before restarting your PC.
  3. Check that you have permission to play the specific MP3 files if you are having playback issues. Occasionally, songs purchased through the Yahoo! Music online store using MusicMatch Jukebox Plus have faulty digital rights management (DRM) protection. Burn the file to a CD and then rip the song from the CD as an MP3, which removes the DRM protection and allows the software to play it without restrictions. This is your only recourse, as the MusicMatch store no longer exists. Previously, you could have contacted MusicMatch's customer service to have the song reissued.
  4. Reinstall the MusicMatch Jukebox Plus software. Click the "Start" menu button in the lower left-hand corner of the screen and select "Settings." Open your "Control Panel" and double-click the icon named "Add/Remove Programs." Locate "MUSICMATCH" in the list of available programs and click "Uninstall."
  5. Insert the MusicMatch Jukebox Plus installation disk into your computer's disk drive and follow the on-screen instructions to install the software again. This may resolve problems involving faulty computer files and corrupt Windows Registry data.
  6. Clean any CDs you are trying to rip or record to using the MusicMatch software. Disks with unclean surfaces involving dust or fingerprints are some of the most common reasons for faulty MP3 ripping or poor audio when recording CDs. Use a specialty disk cleaning cloth or a cloth intended for cleaning similarly sensitive accessories such as prescription eyeglasses. Wipe the disk from the middle toward the edge.please rate and comment on this product just by saying how helpful it is.raise the thumb up
Dec 21, 2010 | Computers & Internet
I have a wurltzer CD 100 disk player. I think the
Either the CD player, CD control unit, or Selection & Credit Computer are defective. I can help over the phone with troubleshooting, please email tech@wurlitzer-ohio.com.
Jul 30, 2010 | Wurlitzer Jukebox CD Player
Need a software download or disk
I was given this nomad jukebox zenxtra . Does this auto device come with a software disk? I do not have one for this product.How do I get the software and get it downloaded on my computer.
Feb 02, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Cannot get my computer to recognize my Dell Jukebox
Assuming that you don't have windows vista, you can load the Dell DJ Explorer program that came with your DJ. It comes up as a regular looking window that should "see" your DJ when you plug it in. If it doesn't, where it says "not connected", right click and then click refresh. Sometimes it works better to plug in the DJ first, then load dj explorer. When it sees it, "not connected" should change to the name of your DJ. Double click that and it should then 'read' your dj, showing all the files on it. Then its just a tedious amount of copy and paste to another folder on your computer (like your My Music folder), and your music is restored to your computer. Take care, as DJ Explorer can also delete files from your DJ if you tell it to.
If you no longer have the DJ drivers and DJ Explorer and Musicmatch loaded on your computer, you can still download that stuff from the Dell site.
If you Do have Vista, try to find a friend with XP. Load the DJ explorer software on their computer, and pull your music off the dj to your friend's computer, then use a USB drive or something to move it to yours. Or better yet, upgrade your computer from VIsta to Xp (yes, I said upgrade - Vista is ****)
Jan 28, 2009 | Dell DJ MP3 Player
Does not hold memory of programmed options
I do not know what type of jukebox you have but the the battery will be in the Central Control Computer, this is the case with the Rowe Ami version of your jukebox. It is a 3 volt lithium (disk type) battery.
Regards
Alan Hood
ami-man
UK
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Nomad Zen Xtra 40 GB Jukebox
Download creative mediasource5 BUT ALSO the nomad plugin, then your computer will pick it up
Sep 12, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Proposed solution
Creative Jukebox 3
  1. Remove the battery cover
  2. Partially remove the battery
  3. Press and hold STOP button
  4. Slide the battery back into position - the unit should power on.
  5. When the CREATIVE logo appears on the display, release the STOP button then immediately press and release the PLAY button.
  6. The following options will appear on the display:
  • Clean Up (Performs a disk scan on the players hard disk)
  • Format All (Formats the players hard disk - Note: all contents will be lost)
  • Reload Firmware (Reloads the Operating System on the Jukebox. Note: Reloading your OS, will not effect the contents of the files stored on your Jukebox Zen. Select this option ONLY if you have access to a PC and you have downloaded the necessary firmware to install.)
  • Reboot (Reboots the device).
Aug 16, 2008 | Creative Labs Nomad Jukebox III MP3 Player
Deleting files
If you've got it connected to your computer, you can do the same things that you would with any connected hard drive. In this case you should be able to delete files and then empty the recycle bin.
After that, go to My Computer and right click the icon for your Jukebox and select Properties. There you should be able to use Disk Cleanup to purge old system files, etc.
Oct 30, 2006 | Archos Jukebox Recorder MP3 Player
18 people viewed this question
k24674
jasbo
jasbo
