Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch dishwasher will not start up ,flashing red light indicating 1 remains on panel any solutions?
3 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: bosch dishwaser
need to look at operating booklet and see what F stands for.then rectify it.
Posted on Oct 08, 2007
Poohs
  • 4 Answers
SOURCE: BF162 Hotpoint intergrated dishwasher
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
I have a Bosch dishwasher SHX68T52UC/02 that has stopped working.
Hello!
Here you can find manuals to a huge range of Bosch dishwashers.
Hope you find a solution.
https://manualsbrain.com/en/brands/bosch/dishwashers
Aug 31, 2017 | Bosch Dishwashers
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
My Bosch dishwasher won't shut off. The timer says "1" forever and when you open it there is about an inch of SOAPY water still there.If you press start it goes to "13" and again counts down to "1" and...
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Feb 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
DISHWASHER WON'T START,ALL LIGHTS ON PANEL FLASH RED
how to download the game gat4 (i don't know ENGlish )
Feb 15, 2009 | Kenmore 24 in. 17052 / 17054 / 17059...
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
552 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
