Question about Vacuums
I have an LG hoover VKC902HT, I have cleaned out the filter and washed the part that holds the dust and now when I use it it pings all the time.
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Posted on Feb 21, 2008
SOURCE: filter keeps clogging
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=719779
Generic problem for all Vacuums
Filter keeps clogging
Posted by ozandcaza on Jun 29, 2008
Report abuse
Dust etc collects in the filter above the dust container. The dust container remains empty. Hoover then over heats and cuts out. Collect in replaced new filters in Hoover but problem still remains.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My question is how old is the Hoover vacuum? If it less than a year you should really see an Authorized Hoover vacuum cleaner dealer that the problem might be covered under a factory warranty. This should not be happening and it sound to me like there is a clog somewhere in the vacuum fill area that is causing it to do this to you and the vacuum. You are lucky that you have a thermal switch that does shut it off. If not and it is over the one year factory warranty then you should see a local vacuum cleaner dealer in your area or contact Hoover Cust Serv @ the website and or phone 3 listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
  • 6 Answers
SOURCE: RED Flashing clean button with NO START
Try wiping off the cliff sensors, and cleaning the drive wheels. Download the user guide, if you don't already have one.
Posted on Oct 28, 2009
My vacuum has lost the suck when I try to use the hose
Hey there! It sounds like you may possibly have a clog in your hose. Try removing the hose completely from the vacuum from both ends. Use a broom stick to loosen and remove any clogs from the hose. Your filters can also affect suction power so be sure to clean and replace any filters if needed. Hope this helps!
Jun 28, 2014 | Hoover Vacuums
Blowing dust out even after cleaning filter
the bagless containers of these vacuums do tend to hold a strong dust odor. the only way ive found to help eliminate it is with a product that i use called FreshWave odor neutralizing pearls. you never want to use fine dust carpet freshener or any product like that cause it will eventually burn up your motor. but if you are interested give me a call and i can ship you some of the freshwave. 703-724-1112
Apr 11, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
My dyson d70 won't pick up efficiantly, i have been hoovering plaster up previous to this. i have lost my user manual and can't remove the fillters to clean them.
Plaster dust is very fine and can get into the motor. Clean every part of the suction system, I've seen them be full of plaster pieces blocking the flow. Wash or replace every filter, dry before trying again.
Jun 06, 2010 | Vacuums
Hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Apr 17, 2009 | Hoover Powermax S3530 Bagged Canister...
I need to clean the main filter
Be sure you wash the filter that is above the canister compartment. It has an orange lever to release it. I over looked this the first year I had the vaccume, dust was really caked in there. I also just wash out the inside of the canister with water once in awhile.
Mar 18, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
take it outside and bang it against something hard like a rock of a brick.
Mar 18, 2009 | Hoover U5753-900 WindTunnel Bagless...
How often should I change a hoover empower filter?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545652
How often should I change?
Posted by jdl185 on Apr 25, 2008
How often should I change a Hoover Empower filter?
Depending on what type of filter it is, the suggested change for a filter is every 6 months to one year if it is a cartridge filter or HEPA filter, if it is a filter that can be vacuumed off or it might be a washable filter – you can clean it that way until the filter starts to fall apart – then @ that time you would want to replace it @ that time. Please check with you local vac dealer. Filters
It's important to replace your vacuum filter or HEPA filter regularly to keep your Hoover vacuum working best. Not only will this increase the life of your vacuum, it will also keep unwanted dust, dirt and allergens out of the air. Keep your home Hoover clean with genuine Hoover filters.
So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Feb 20, 2008 | Vacuums
Hoover u5720-900 quits running and restarts again after some time
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Jul 27, 2007 | Hoover U5720-900 WindTunnel Upright Vacuum
Vacuums Logo
67 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
