Question about Logitech Z323 2 Speakers
My logitech z323 speakers have "stopped" working. i say it this way because whe plugged into main power they constantly turn on and off
  • 7 Answers
SOURCE: MY logitech speaker power indicator is not green
I own the ones you have I have had no problem so far, although by the sounds of it there may be something wrong internally and would require a repair or else purchase brand new speaker.
Posted on Mar 03, 2011
Idahoodini
  • 82 Answers
SOURCE: i just got the logitech
Logitech speakers connect with a cable that fits into something like an iPod or computer (Usually with a green tip). If your TV uses the usual 3 connectors (White Red and Yellow) you can go to the store (Best Buy, Wal-Mart, Online, etc.) and purchase a converter that will convert the Red White and Yellow cables to the Green cable. These are cheap and involve no electronics, but make sure that you buy one that has a male to female connection (will plug IN to your TV and has an opening to plug the green cable into)
Posted on Mar 14, 2011
  • 961 Answers
SOURCE: my Logitech Z323 2.1 Speakers
Is it internal or USB?
Posted on Mar 25, 2011
bronk50
  • 27725 Answers
SOURCE: i connected a mic to
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Posted on Apr 19, 2011
bronk50
  • 27725 Answers
SOURCE: About 2 weeks ago i
a possible WARRANTY issue
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on May 04, 2011
I have recently purchased the z323 speakers and from the first day i have the same problem It works great but every few hours it suddenly stops working amd the power light turns a paler sade of orange I...
Very strange fault indeed; you reports here. There is nothing more to check. See the power output plug at your home. If it has any fault, that is, if it do not fit with the power plug the device you have; this kind of fault can occur due to loose power connection. Gopakumar Gopalan Google
Feb 23, 2014 | Audio Players & Recorders
Left speaker not working
This has just happened with my Logitech Z323 left speaker. I wanted to know if you were able to fix the issue?
Feb 08, 2014 | Logitech Z323 2 Speakers
I have logitech Z4 speakers, and my speakers always just stop working, then when they're un plugged and re-plugged in they start to work again. This issue used to happen every couple of days, and
• One possible reason could be a faulty power supply for the amplifier.
• Transformer could be overheating or possibly the main amp itself.
here is a link , should you need to DIY
or just a guide and use it as a reference.
404_118x100.png Computer Speakers
let me know if you need more assistance.
Sep 11, 2012 | Logitech Z4 Computer Speakers
About 2 weeks ago i received some logitech z323 speakers as a gift and was very pleased, however the right speaker has now stopped making any sound at all, i have checked the connection to the sub and...
hope this helps
May 04, 2011 | Logitech Z323 2 Speakers
I connected a mic to the Logitech Z323 speaker input but the mic doesn't work do i need a special driver or software?
Apr 19, 2011 | Logitech Z323 2 Speakers
I just got the logitech z323 speakers for my computer and i wanted to see if i could hook them up to my sony flat screen. i was wondering if there is a way to do that and if so how?
Mar 14, 2011 | Logitech Z323 2 Speakers
Any suggestions where to get a replacement volume knob for a logitech z323?
You can contact Logitech Team at the following # :
1-800-231-7717
Monday - Friday, 6:00am - 6:00pm PST
Saturday - Sunday, 7:00am to 5:00pm PST
Mar 05, 2011 | Logitech Z323 2 Speakers
My logitech r20 speakers problem is when i switch on ,there is no power come out,but then if i push a bit n hold ,there is power come out,.if i release back my hand switch it to normally the button...
The power button on your speakers is broken- possibly from friction due to heavy usage. Unfortunately, there is no way to really fix this that is worth your time- if you still have it under warranty, take it to where you bought it, or give Logitech a call to get them replaced. If you don't, it may be time to search for a new set. While it's more expensive, I would recommend the Logitech Z-313 or Z323 if you want a decent replacement. They will sound better than the R20s, too.
Dec 17, 2010 | Logitech R-20 Computer Speakers
Logitech Z323 2 Speakers Logo
170 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
