Question about Peavey PR® 10P Main / Stereo Speaker
Peavey Model PR-1003, needs replacement low frequency driver what is it ?
Where can i find tech service manual for Peavey PR15 speaker?
The PR 15 is a two-way sound reinforcement system consisting of a heavy duty 15" woofer and a RX14™ titanium diaphragm, dynamic compression driver mounted on a 90° x 40° coverage constant-directivity horn. The lightweight-yet-rugged injection-molded plastic enclosure.
There is no need for any other service data and there is no service manual apart from user manual. It doesn't warrant one.
Apr 08, 2017 | Peavey Music
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
Speaker rattle
Yes, but you need to replace the entire speaker. The 1505 and 1508 use a different magnet though they look similar..
Jan 20, 2014 | Peavey Music
How do i change the diaphram in a peavey pr 15 speaker
Take the hf driver off, then disassemble the old diaphragm and insert the new one, check the light bulb at crossover network to avoid late issues.
Jun 21, 2011 | Peavey Amplifier GT-15-FX - Black
What was the glowing inside my peavy pr 15 pa cabinet when I turned up my treble on my pa amp by accident? There was no damage I was just curieous as to what that glowing was
There is a speaker protection circuit that uses a lamp that will light IF you are driving the spoeakler TOO HARD !!! You can search for "Peavey speaker protection" circuiot online.
Jun 13, 2011 | Peavey XR 8600 / PR 15 PA Package
I have a two way peavey p115 speaker system and audio has stopped coming out of the high frequency driver . I tested the high frequency driver with a multi meter and it is fines.I also have a working...
Testing the driver with an ohmmeter is incomplete test. Sometimes the magnets break off the drivers rendering no sound. Sometimes the voice coil shorts and if you don't interpret the ohmmeter readings correctly you can overlook a faulty driver. Remove the horn and look for damage such as lost magnet from the back. Also the peavey cabs have a protection circuit so if you did not try another speaker to the same wores going to the driver, it may be the Polyfuse on the protection circuit or other components.
May 02, 2011 | Peavey PV 115 Speaker PA Passive
I am terrible as music equipment. so here is my dummy question. I hope you can help me out. I bought a used Peveay PR Subwoofer similar to this one: http://www.guitarcenter.com/LMS/Viewer.aspx?vid=48691...
hello, first off you bought a sub designed for musicians not for use at home. tons of issues pop up how many ohms is the driver does it have a crossover what frequency is is tuned for etc...? too many issues .
if you are determined to make it work
first thing you will need a MONO amplifier or a stereo amp that can be BRIDGED to mono
then you will probably have to replace the phone jacks with speaker terminals they are available at radio shack or most car stereo installation shops.
Personally I would not mess with it chalk it up to a "life lesson" and purchase a sub with an onboard amplifier that is designed to connect to a home receiver.
Dec 22, 2009 | Peavey PR® 10P Main / Stereo Speaker
Peavey eurosys 500 watt 4 ohm pa speaker fault.very low volume.
Sounds like the basket has gone on the driver not sure if they are replaceable or if you will have to replace the entire driver, had the same problem on my impulse 1015, cost about £100 from a peavey dealer.
Dec 04, 2008 | Peavey PVM 22 Microphone
Peavey PR® 10P Main / Stereo Speaker Logo
120 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
shaqsatin
Level 1 Expert
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
