Question about HP Presario C504US (RQ334UA#ABA) PC Notebook
Power light blinks but it does not boot up with hp compaq presario c504us
  • 66 Answers
SOURCE: power up problem
The battery is dead. I have a compaq too and when this happens it is because thebattery has run out. As stated above plug it into the wall and hopefully your battery will charge.
Posted on Jan 30, 2008
leecom72
  • 4806 Answers
SOURCE: Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
Posted on Nov 26, 2008
  • 12 Answers
SOURCE: Compaq Presario c300 power light blinks..
It sounds to me like there's a short in the AC adapters causing it to have enough power to charge the unit when it's not pulling power, but once it starts pulling power, it basically becomes overwhelmed and can't do both power and charge. There's also the chance that the DC jack [which the AC adapter plugs into] is bad. However I'd suggest checking the adapter first because it's simple to obtain a new one and if it doesn't work, you can most likely just return it and say it doesn't work as opposed to a dc jack being repaired which would have to be done by a professional with the skills to handle it [of course unless it's under warrenty, less than a year old, but judging by the model I'd say it's probably not]
Posted on Nov 27, 2008
RescueTechLA
  • 2653 Answers
SOURCE: compaq presario v5000 won't start or post
It's the motherboard. Check to see if yours is still under warranty even if you've had it for over a year.
HP / Compaq has recently extended their warranty period for certain models.
Warranty Check
Let me know if you have any other questions.
Posted on Mar 04, 2009
walesarumi
  • 6993 Answers
SOURCE: HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Posted on Dec 03, 2009
Testimonial: "awesome, thanks, i'll try that :)"
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Not booting hp presario f700
hit the f5 key then follow the screen from there that is in safe mode
Mar 21, 2014 | HP Compaq Presario F500 F700 and G6000...
Compaq presario won't boot caps lock blinking power button on
hi
maybe you have change the keyboard , it is failure
Sep 05, 2012 | Compaq Presario Notebook
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
My HP Compaq Presario SR2170NX starts up but won't load
  • Make sure you computer is powered off
  • Turn your computer on and start hitting the F8 key
  • An Advanced Boot Menu will come up with an option to boot into safe mode
Restore your PC to the date when its performance was good.
Use a system utility software like RegInOut to fix this issue.
Hope it works for you.
Dec 26, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I have a Compaq Presario SR2010NX that will not boot. When I plug in the power cable, a green light blinks at the back of the tower on the power supply. I was given the desktop in mint condition, which...
your power supply is bad. the blinking light means there is a failed component in the power supply. replace the power supply and you will be good to go. around 60 dollars at any computer place. please rate me thank you.
Jan 04, 2011 | HP Compaq Presario SR2010NX PC Desktop
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Compaq presario laptop blinking power button
REMOVED BATTERY AND CHECK ONLY IN AC MODE
IF ITS START PRESS F8 AFTER BOOTING AND OPEN IN SAFE MODE
Jun 21, 2008 | Compaq Presario Notebook
Computers' power light is blinking and will not power on
This normally means that the computer is in standby mode all you need to do is press the power button. If this does not work then hold the power button in for about 10 seconds until the computer turns off then wait a further 10 seconds and turn back on and boot normally.
Please let me know it this works and please rate me. Once you booted normally set the power options within control panel not to go into standby.
Cheers J
Jan 01, 2008 | HP Compaq Presario S3000nx (DC475A#ABA) PC...
HP Presario C504US (RQ334UA#ABA) PC Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
