Question about Rainbow E series Canister Wet/Dry Vacuum
I have the rainbow E series and the coupling that locks the hose in the wand has broke. I have ordered some coupling, but I believe half of the coupling managed to be sucked in by the powerful vacuum cleaner. Is there a way I can disconnect the hose to see if I can reach the coupling?
  • udab May 29, 2011
    That you for your simply strategy, however there is not a lock to press.
  • 1,238 Answers
Good day!
Please try this simple strategy to pull out the host.
If you hose have a lock press it then shake,shake it while you pulling out the host with mild force.
I hope this simple strategy will help you to pull out the host and if you have other question just add a comment.
thank you
Posted on May 29, 2011
  • bonifacio gomez
    bonifacio gomez May 29, 2011
    If you don't have lock to press,
    try to twist the hose in counter clockwise while you pull the hose with pull force.
How does the nonelectric hose detach from the wand on rainbow e series to connect to aquamate
Rainbow E Series attachment hoses fit the wand with friction. The wand will just twist and pull out of an attachment hose. Now for use with an Aquamate, if you have the newest aquamate like here:
Rainbow AquaMate 3 carpet shampooer , the aquamate needs an electrified hose made for water pickup and a stainless steel long pipe (stainless steel so it will not rust, you can use chrome but it will rust) .
Vacuum Repair Technician
800-775-6586
GoodVac.com
Feb 17, 2015 | Rainbow Vacuums
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
How do i clean the hose wand & nozzle of rainbow vacuum
if the wand is not to dirty I suck up a cup or two of water. then put the hose to the exhaust side to dry it out for a about 4 to 5 minutes
Jan 08, 2014 | Rainbow 75th Anniversary Canister Vacuum
On my rainbow e series the power nozzle roller isn't spinning when I press the trigger even though all power is working fine. The roller is fairly new. I've also checked that nothing is blocking the hose...
Power must run from the vacuum through the hose where the trigger mechanism closes the circuit and allows power to pass through the hose to the wand, then to the power nozzle. A short or bad connection in any of these areas will cause the power nozzle motor to not run.
Oct 09, 2013 | Vacuums
No spinning in the power head
First, check the red reset button on the power nozzle head. - if it's popped out, push it in. Also, if you have a switch on the handle, make sure you're pressing it while you're vacuuming. if those obvious solutions are already remedied, you may need to check the power outlet on the canister for voltage with a voltmeter while the vacuum is running, and then check your power hose and wand for continuity (checking for a broken wire) while the hose is disconnected from the canister. If all this checks out and the power nozzle still doesn't power on, you may have a bad motor in the power nozzle. If you're good at taking things apart, then it's a simple fix to replace the power nozzle motor.
Jul 03, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow D3C electric Hose is broke
NO NO NO NO you have to get a new hose in this situation there is no other way around it. If you screw up just the littlest bit reattaching that hose a vacuum that uses water will QUICKLY let you know. Do yourself, your family, and your life insurance company a favor and buy a new hose.
Apr 10, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Feb 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series
It could if the separator is binding, or dragging, when it turns, causing the motor to over heat, that maybe what you are smelling. If it is, then replace the separator.
Dec 29, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
Nov 30, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
100 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
