Question about Vacuums
Roller has stopped working?!? - Vacuums
Roller stops working after just a few seconds
Haven't had this problem, but sounds like an obstruction of some kind. Turn the vacuum upside down and clean any lint, thread or hair around the roller and make sure there is nothing stuck in there that would impede the roller. I have a long haired dog and have to do this regularly.
Jun 19, 2014 | Shark SV1100 Navigator Freestyle Cordless...
Roller not turning when vaccuming
just had the same exact issue with mine - took everything apart - found that the swivel roller brush wasnt turning. it was not any belt issues or motor issues. took out brush roller - held in my hand by holding just the hand cap still - and tried turning the roller with my other hand. roller would not turn at all but is supposed to with no effort. on some models the end caps pop off but most are one piece and are just discarded and a new roller bought - seems to be $10-$20 for one for most dirt devils and under $10 shipping in north america. you can try something down the side of the roller and end cap like a razor - i did cut lose some crud and it works - but roller still stops on 2 of 4 settings on the rug because of this. i've already ordered a new one.
Mar 11, 2013 | Dirt Devil Vacuums
Dc 24 roller brush quit working....belt is okay & there are no obstructions on roller or in head compartment & suction at head is strong
Hi there, sometimes a stretched belt will hamper the vac. from picking up. he best way to test this is to turn the machine on, then carefully put you hand on the roller. If the belt is stretched the roller will stop turning when you apply pressure. Hope this helps, Chris
Feb 09, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
The roller brush stop working
the fuse in the plug may have blow so replace it any ways
Jul 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Roller wont spin
is there hair, strings, twine wrapped around the roller? perhaps this is the issue, is there still suction by the rollers or has this stopped as well?
Jun 12, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush roller stopped rolling
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
Nov 25, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Sep 05, 2007 | Bissell 37603 Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
