White screen and black vertical lines over half of la26b450 model tv screen
  • 517 Answers
Good day!
that problem is on the cable please try to play dvd or recorded tv shows.
if you play dvd or recorded shows and picture is normal
try to check the connection of your cable and try to touch the connector and move it gently then see the picture of your TV if there's changes
thank you
Posted on May 29, 2011
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
I HAVE A HALF SCREEN. BOTTOM HALF LOOKS GOOD TOP HALF HAS WHITE LINES WITH A BIGGER WHITE LINE SEPARATING THE TWO. IS THE PICTURE TUBE GONE OR IS THERE AN ADJUSTMENT I CAN MAKE? TV IS A RCA F25645
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
Jun 15, 2011 | RCA F25645 25" TV
I see 11 flashing groups of about 4 ununiformely-doted lines (black and white) on my screen. Ech group of 4 lines is separated from the next by about the same width of the group (i.e. the screen is divided...
there maybe some problem with the vertical circuits with your tv, if you are still satisfy and tv is viewable then patiencely watch it. however as times goes by using it, if the defect is not corrected it may worsening the vertical circuits problem. scanning vertical trace is the problem of your tv.
Feb 06, 2011 | Pioneer PDP-4271HD 42 in. Plasma...
White line across black screen (setup mode?) model
if line is horizentle check vertical ic supply and out put capcitor if line is vertical check yoke wirsand cap 560k at horizentle yoke and any print brunt
Jul 03, 2010 | Quasar SP-2725 27" TV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
CRT TV with a white line half way up the screen
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Jan 05, 2009 | Televison & Video
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
