Question about OKI C5650n LED Laser Printer
I have a oki C5650 and dont have de netwoork menu because i made a flash format. Can you tell me how save the new firmware. thanks.
5 Suggested Answers
  • 97 Answers
SOURCE: Oki C5500 dont have TC/IP menu, do you help me.
Symptom:
Unable to reach Printer from local network or Printer falling off network and needs to be rebooted before being able to print
Cause:
ecblank.gif ecblank.gif ecblank.gif Resolution:
Install OkiLAN8300e Firmware 4.06 (C5500/C5800) or 4.55 (C6100) update using Oki LPR Utility
Are you on a Mac?
Posted on Mar 29, 2010
SOURCE: falal error 173 on oki c5650 after changing fuser
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Posted on Apr 23, 2010
  • 132 Answers
SOURCE: OKI C5650 PAGE PRINTING WITH NO INK IN MIDDLE OF
Drum worn-out
Posted on Nov 20, 2010
  • 1116 Answers
SOURCE: OKI c5650 flashing "K drum life" I buy new charge
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 08, 2011
My Oki C5650 is showing all 4 3rd party cartridges as incompatible.
For the printer to do this of its own accord makes me think the main board has thrown a wobbly. As you know how to get into the maintenance mode, scroll to menu reset and this will reset the eeprom. I doubt if it will cure it without new drums. You can buy on the internet a stick-on fuse for the drum which will blow and reset the printer into thinking its a new drum. Do this for all the drums and it may just do the trick. If its toner related then only genuine toners will cure. Anyway the fuse trick is the cheapest option. You may think why drums when its toners. That's because you need to fool the printer into thinking parts have been changed and it may have a knock on effect. Its worth a try.
Jun 11, 2017 | OKI Office Equipment & Supplies
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
I have a Ricoh 161 but after a firmware update erro (NIB) the machine tries to continue the update. How I cancel the firmware update or reset the firmware in the machine? ----------------- Eu tenho uma...
You can not stop a firmware update.
Did you turn the machine off while the firmware update? If you did that your NVram is broken
I think that the only chance you have is with a new NVram. Sorry but you will have to put a new NVram.
Jun 10, 2011 | Ricoh Aficio MP 161 Black and White Copier
8. Restart printer.
Jun 08, 2011 | OKI C5650n LED Laser Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Symptom:
Cause:
Are you on a Mac?
Mar 10, 2010 | OKI C5500n Laser Printer
How I can reset drum for OKI c5650?
I have no "NV-Ram initial" menu on my C5650... any help?
Mar 08, 2010 | OKI C5650n LED Laser Printer
We're seeing heavy pixelation on all of our prints.
I would try going to the color menu on the printer and performing the density and registration calibration that should cure your problem hope this helps.
Nov 25, 2009 | OKI C5650dn - 1212601 - - Laser Printer...
OKI C5650n LED Laser Printer Logo
293 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
