Question about Asrock N68PV-GS Motherboard
N68 no audio output - Asrock N68PV-GS Motherboard
    President:
  • 1,851 Answers
You have to download and run (install) the audio drivers. From this official link select your operating system (Wnindows XP, Vista, Windows 7)and download the proper audio drivers.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 29, 2011
Audio Problem :- Motherboard - ASRock N68-VS3 UCC
Windows 7 has sooo many different options for audio it is confusing. If you right click on the (windows) speaker icon in the system tray and click "volume control options" you get one set of features.
If you click on the "sound" icon in the device manager you get entirely different results!
And lets not forget that your sound card probably has its own audio configuration utility!
I have found that sometimes you have to play with all of these programs to get the sound to work properly.
Getting windows to recognize the "default" seems to be the biggest issue.
Oct 15, 2013 | ATI Asrock N68-vs3-ucc Ddr3 All-in-one Am3...
Asrock N68-S3 UCC Windows 7 64 bit. Integrated soundcard was working but stopped. Not visible in Device manager. Nothing BIOS to assist.
http://www.asrock.com/mb/download.asp?Model=N68-S3%20UCC&o=All
Try re-installing the drivers and see if the computer picks up the hardware on your next reboot. If you're having trouble getting audio from the front panel of your desktop, try using the back panel. If it works then the cabling inside of the computer to the front panel might have become detached.
Aug 02, 2011 | Asrock 775i65G Motherboard
HP Photosmart C4580 Print cartridge(s) missing or not detected
This error message usually happen if the cartridge is not properly seated or the copper-colored electrical contacts have problem. Check this website for proper cleaning and installing ink cartridge.
If the problem is resolve try replacing the ink cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01442936&lc=en&dlc=en&cc=us&lang=en&product=3418707#N68
TNX
Apr 23, 2011 | HP Photosmart C4580 All-in-One InkJet...
How do i upgrade my built in vga without buying video card? n68-s ucc
the highest the video can go is 256meg and is adjusted in the Bios an depends on how much ram memory you have installed but yo can upgrade to a PCI-E video card.Here is the manual for the board.
ftp://174.142.97.10/manual/N68-S.pdf
Feb 15, 2011 | Asrock N68S Ucc Socket AM2+ GeForce 7025...
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Yamaha RX-V661 - no audio since I hooked up digital converter box
Immediately you have the problem of TV audio out to DVR audio out. Inputs go to outputs and outputs go to inputs - always.
I think what you may want to do is daisy chain all your audio (e.g. audio output of Tivax to audio input of VCR. Audio output of VCR to audio input of DVR. Audio output of DVR to an audio input of the Yamaha) In order to get the audio from any given device to the reciever, you may have to power up all of components.) Of course in order to record on the VCR and DVR you would attach the antenna to the RF input on the Tivax , RF output to the RF input of the VCR, RF output of the VCR to the RF input of the DVR and finally the RF output of the DVR to the antenna input of the TV. I don't know whether there would be any losses in such an elaborate hookup such that the RF signal would not be strong enough to get stations but you can experiment by just taking links out of this daisy chain. Hope this helps.
Jul 03, 2009 | Audio Players & Recorders
I,m trying to replace my kenwood KD 47F turntable V68 catridge & N68 needle stylus with an Audio technica set due to non availibility of N68 stylus in my home country- singapore. Audio technica...
hi, any cartridge are posible in every turntable as long the needle is available...the wiring is the same the position ,, but the only thing that im not sure is the sensetivity of the needle ..some are not good but some is compatible..u
Jun 30, 2009 | Kenwood KD-291RC Turntable
Cant find audio output
On the earlier model AOC 32", there was only 1 audio output in the form of a digital Toslink output (fiber optic). An updated model was introduced in late 2008 which included a left and right phono audio output. The only ways to combat the lack of phono audio output on the earlier model are to either, A: Purchase an analog to digital converter online, or B: Go through a device with an analog to digital audio converter built in. Something like a stereo receiver should do this without any problem. Hope this helps.
Mar 25, 2009 | AOC Envision L32W461 32 in. LCD HDTV
Asrock N68PV-GS Motherboard Logo
162 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
