Question about Samsung LN-S4692D 46 in. LCD HDTV
Keeps resetting back to dynamic
Television keeps going back to dynamic after about 25 min how do I stop this please help if you can
  • Anonymous Mar 21, 2014
    samsung tv sound keeps going off, by itself. i got it reset before and cant remember how to do it can you please help
  • 3 Answers
I understand that you dont want to run your LCD in 'Dynamic' mode all the time! I don't! Its a great way to preserve the life of the backlight... All I can suggest is unplugging the Set from the wall outlet for 10 seconds, then plug it back in-- hopefully this resets the unit -- otherwise this is a defect and hopefully you have a warranty that is still valid!
Good Luck!
Posted on Aug 18, 2008
Changing viewing mode
what TV and this is a default, consult manuel
Mar 27, 2014 | Panasonic VIERA Televison & Video
My tv cuts off then it won't come back on when powered on the power button light just keeps flashing. After unplugging tv for 20-25 mins it will come back on
CRT screens use a vacuum tubes for displaying purposes. These tubes warn off through time and use, with symptoms like colours fading out, late responce on start and even quit doing what they suppose to do.
My solution is to replace the warn tube with a new one,if you really want to keep this screen properly functional, but this could get to much trouble and cost maybe.
Feb 20, 2013 | Televison & Video
What are the best settings so that i can get the best picture from samsung plasma tv model PS50A457P1D?
hi can i just add? I have recently got this tv but for some reason when i set setting to Normal they reset to dynamic?? After about twenty mins? I keep having to change back to normal or if i set it to perfect brightness etc... it just goes back to dynamic again? i.e cell light 100% and contrast up to 100%!
Why is this??
Mar 09, 2012 | Samsung PS50A457 50 in. Plasma TV
The TV will, on t's own, will go to the DYNAMIC (Fixed) setting every 30 mins. or so and I have to go to the settings I like. Then it will go back over and over again.
hello,
Dynamic (Fixed) setting every 30 mins. Then it will go back over and over again because of store mode has selected. To remove or set to home mode you can enter initial setup. Follow the instructions from TV set . Or enter TV location from menu than choose home.
Good luck.
Apr 01, 2011 | Sharp LC46SB54U 46 in. LCD TV
I used to be able to change picture mode (dynamic fixed) (standard) etc.. but now stuck on standard. I have lost the picture mode option and can't get it back to the brighter richer (dynamic fixed mode). ...
Go in the tv menu,right at bat u in the Picture mode go down the menu to reset push it.The Tuner board will reset it self.It will be set on the Dynantic fixed mode.And the AV mode button on the remote should able to changes back and fourth again Dynamic fix mode,Dynamic mode,Standard mode,User mode,Game mode.Not able to changes by pushing the remote button AV mode to changes,than ur Tuner board have problems,not working properly.
Jun 09, 2010 | Sharp AQUOS LC-52XS1U-S LCD TV
My Samsung32'' resets to default settings every 30 mins!
Hi reset the tv and put it in to home mode!!!!
Shop mod resets tv settings every 30 mins
Apr 13, 2009 | Samsung Televison & Video
SHARP LC-32SB24U. AV MODE KEEPS GOING BACK TO DYNAMIC FIXED .
I have the same tv and i just fixed it! mine was a display model at wal mart so it was set to reset to Dynamix (fixed) after 30 minutes of no remote activity
THE FIX: switch to TV MODE and select the EZ SETUP from the option menu
when you get to the TV LOCATION option select HOME
The STORE option resets the TV after 30 mins of remote control inactivity in case someone messes up the picture settings in case someone playing with it while it was on display at the store
Jan 18, 2009 | Televison & Video
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
My brightness keeps resetting
i had the same problem....... on the actual tv u have to press and hold the volume button and menu button together for about 5 seconds and then on the screen it should say dynamic and that hopefully will sort it for u. Worked for me :)
Dec 27, 2008 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Le32m87bd
Turn the TV off, Press in sequence... Mute-1-8-2-Power. A service menu will pop up. scroll to reset. This will reset the TV back to factory. This should clear up that bug.
Best regards
Circuitcity
Dec 09, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
105 people viewed this question
Henry  Thomas
Henry Thomas
