Question about Zoom X6 (5590) DSL Modem (55900003)
Hello, I keep loosing internet connection, how can I tell if there is a problem with the modem?
  • 58 Answers
Try to check the status of the lights on your modem. Try to check the light in globe icon, that is the icon for your Internet status, if is GREEN it mean to say that it has connection. When it turns to RED, check the DSL light if it is in SOLID GREEN, When it blinks try to check it with your Service provider.
Posted on May 30, 2011
2 Suggested Answers
  • 52 Answers
SOURCE: I have DSL/verizon,modem 6100F i keep loosing my internet connection
I doubt its your bill. Your speed wont be metered, its going to be on or turned off completely.
Your best bet is to phone support for intermittent internet access.
Posted on Aug 27, 2009
Keeps loosing wifi signal
Try resetting your wireless router. Power cycle it through.
Symptoms:
lost Internet access on all devices
unable to go online
no Internet connection on router
router Internet LED symbol is amber
To powercycle your home network:
Turn off the router by unplugging it. If you have a modem and router in one device, turn it off then proceed to step 3.
Turn off the DSL or cable modem for three minutes.
Note: Some modems are equipped with a backup battery. If your modem have one, please remove the backup battery to completely turn off your modem. For common cable modems equipped with backup batteries, please see Performing a full reset of cable modem with battery backup
Turn off all computers attached to your network.
Turn on the DSL or cable modem first and let it boot. Let it complete its connection to your ISP before proceeding to the next step. One of the indications that the modem have completed its connection is by seeing a green light on the modem. If you have a modem and router in one device, proceed to step 6 after it connects to your ISP.
Once the modem completes the connection to your ISP, plug in the router. Let it complete its power on test before proceeding to the next step.
Restart your computers.
Jan 09, 2015 | Computers & Internet
Hello, I have x-lite on my computer, i can make VOIP cal for a limited time only, then I loose the DSL connection, and the dlink modem require restart (internet status went off). any support please
Does this problem (internet status off) happen even when you are not using x-lite?
It's very unlikely that it's the software disturbing the connection. I suspect your VoIP calls are interrupted because the connection is dropping, and not the contrary.
May 09, 2011 | Westell Wirespeed LiteLine 6100...
Modem keeps loosing connectivity. I have to turn off the modem and restart it to access the internet. Running 2Wire Gateway.
call your internet service provider and report first this incident. in most cases its with the service provider that has problem causing disconnection in your internet.
Take a look also with your modem device, observe when you got disconnected does led indication lamp turn off or your modem restarted itself. that could also be a problem with the power supply of your modem. better check with multitester if output voltage from power supply is dropping.
go check also the ethernet cable if this is not loose, fix it properly, you should hear a snapping sound means it is lock properly.
Feb 09, 2011 | AT&T High Speed DSL Modem
My laptop keeps telling me that it has limited connectivity to my telstra wireless modem and will not go on to the internet, please help. its very frustrating!!
this is because your internet link from the router to your ISP is failing to connect.
Thus yo are limited to the router connection.
Mar 07, 2010 | Dynalink (V1456VQH) Modem
Linksys WRT54GX4 - SRX 400 Router Internet Connectivity Issues
I had a similar issue a while back and found that sometimes modems are finicky with the MTU settings. I had to throttle mine down about 20 points to get it to stay connected. Check with your provider. Their Tech Support should be able to tell you if there is an alternate MTU setting at work here.
Cheers,
Ron
Feb 21, 2010 | Linksys Wireless-G WRT54G Router
modem did not correct for set up and help to set correct also sorensen router need to set up for modem thank
May 27, 2009 | Westell Wirespeed LiteLine 6100...
I have to power cycle modem as I keep loosing IP address
Depending on the internet provider, most IP addresses are set for a certain amount of time before the lease on them is up, in most cases the modem automatically renews the lease and the modem keeps the same IP address. In some cases, when the lease expires, the modem receives a new IP address from your ISP's dhcp server. In rare cases, the modem does not receive an IP address due to either a failure in the hardware (of the modem, hence faulty modem, time to replace) or the firmware on the modem needs to be upgraded. To upgrade the firm ware on the modem, a call to your ISP's tech support should solve that.
Mar 24, 2009 | Cnet CWR-905 Wireless-N Router
Not sure if i got dsl-924 set up right it keeps loosing internet connection
If ur internet connection is unconnected in between intervals of some 5 to 10 minutes, then it may be problem of ur MODEM or LAN card. The cable may be loose or the device may be faulty.The DSL link setup is perfectly OK. try changing ur MODEM/LAN card with other one.
Oct 11, 2008 | Computers & Internet
Losing connection
I assume this is a cable modem? You need to call your cable company and have a trouble ticket created. I worked for the cable company installing cable for quite a while and I bet my paycheck the signal getting to the modem are below specs and that's why the modem gets dropping the internet connection.
Hope this helps.
Aug 13, 2008 | Arris SURFboard SB4100 Modem
Zoom X6 (5590) DSL Modem (55900003) Logo
284 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
