Question about Bosch WET 2820 Front Load Washer / Dryer
When the clothes are cleaned and removed from the machine, there are little bits of black everywhere
Why is my acer touch screen laptop messed up? It only got a Little bit maybe 5 little drops of water & i took them off right away. But when i swipe the screen the middle gets all scratchy. It...
Depending on what you wiped it off with? Paper towel, Bad. Microfiber cloth for computer screen, good. Shut down the machine, unplug, remove battery, Use the proper cleaning fluid and Microfiber cloth to clean. OR, this: http://www.amazon.com/3M-9027-High-Performance-Cloth/dp/B00006IBLQ
Feb 01, 2013 | Computers & Internet
I would like to oil my elna 6003 but the manual does not show where to oil.
I'm pretty sure these have a wick in the rotary hook under the black plastic bobbin holder where the bobbin sits. Everything else is nylon gears or designed to be lubed during your annual recommended service by an Elna technician.
You can oil the wick yourself (don't do what I did and pull it out with tweezers, dooh). Take out the bobbin holder black bit (your manual should cover this in cleaning) and see if there is a depression/hole in the middle of the metal rotary hook. If so, just put a drop of oil in there once every couple of months.
More important is to clean out the rotary hook well regularly and everywhere else in there, just use the little brush to collect the lint, then wipe it off on a piece of cotton fabric waste to clean the brush, then clean a bit more until no lint remains. Now put the bobbin holder/case back into position lining up the marker point against the stopper. Done.
Hope this makes sense to you and matches what your machine looks like. Happy Sewing, Tally Girl
Sep 17, 2011 | Elna Quilter's Dream 6003Q
My washing machine does not empty the water from the hose, i have checked the hoses when the machine is on its spinning cycle, it only seems if a little bit of water comes out of the machine leaving the...
You need to clean the filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Reassemble and test.
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I need to clean the transfer belt of and HP 2600n and would like to do it myself if possible
You can clean the transfer belt with a soft lint free cloth and little bit of water. You can rotate the white triangular piece to rotate the belt around. Make sure you turn the machine off first, and be very carefull because if you poke a hole or tear the black plastic sheet it will cause print quality problems.
Sep 15, 2010 | HP Color LaserJet 2600n Printer
I have resently purchased a second hand super capacity machine, not yet run it. The softner receptor is very dirty and I was wondering how to clean it out. I have taken the top bit off but am unable to...
You can use vinegar to clean the machine take 100ml of vinegar and two buckets of hot water till the plastic tolerance then start the normal program the hole machine inner unit will be cleaned you can use the same process two months once the cloth cleaning quality will be good
May 17, 2010 | Whirlpool 3.2 Cu. Ft. Super Capacity Plus...
My samsung 245 monitor needs cleaning and accumulates black spots all over. How would I clean that? I tried rubbing them off with a soft cloth, but only spread them
Either buy a monitor cleaning cloth, or use a soft cloth with a little bit of lighter fluid. The lighter fluid will evaporate, so don't worry about getting it off after you're done.
Oct 01, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Washer wont fill with water/clothes dont get clean
Actually the machine is working like it is designed. When the correct soap is used, these machines clean clothes better than the old style. Try using a major brand of soap like Tide, Bold, or Cheer. Make sure it has the HE design on the bottle. This means that it is made just for the new High Efficiency machines. Also make sure you don't use to much. Read the directions. If this is done correctly, I'm sure you will find that it does clean great. I was like you when I first saw one of these new machines. "These is no way you can clean dirty and I mean dirty clothes without enough water to cover them. Well since, I have became a believer. They have put a lot of thought into designing these things. They had to of, for them to clean as good as they do.
Please rate solution
Aug 27, 2009 | Whirlpool Duet WFW9550 Washer
Whines like a dentist's drill when the power is on.
...if all 3 lights are on...
This is a laser mirror motor problem.
If you are a little bit technician then...
Remove all cables, open front panel, remove the cartridge, remove the 2 screws on top and 3 on back side, remove a white latch from underside left (or right i don't remember ).
With a small screwdriver release 4 tabs that hold back cower and remove it.
Pull a little bit on under front edges for releasing two little tabs and remove the whole cover by lifting it..
Now you can see the laser scanner unit with a yellow label on it.
Remove the screw, release the tabs an remove laser cover after removing one or two little cables over it.
You can see now a rotating square mirror fixed over a little disc, secured with a little plastic black tab.
DO NOT TOUCH THE MIRROR WITH BARE HANDS or you will make it dirty .
Rotate the black tab to release the disc, remove the mirror with a clean cloth, and put a small drop of synthetic oil on its rod... that's all.
Hope you can do it.
Jun 29, 2009 | HP LaserJet 6L Printer
Dirty washing
Does your washer smell? Is your rubber door seal gungy too?
If so then use 1/2 cup of Washing Soda Crystals (50p for a 1kg bag from most supermarkets)
set washer to 60 degree wash and run machine for full hot cycle with no clothes in it... just the Washing Soda.
I did this with my washer which literally reeked, and my friends have since done theirs and the results are amazing...
Go and check your drain when you finish too... mine sparkles now and it was gunged up before.. I now add a desertspoon of Washing Soda to every wash.... I place it in the crease of the door seal and little by little all the mould is disappearing, even though the hot wash cleaned the gunge the black spots remained. My washer smells so clean now and no more black flecks on the clothes either... (these are loose gunge from the outer drum, right inside the works of your machine...)
All the best
Sue
Aug 02, 2008 | Hotpoint WF430 Front Load Washer
Open Questions:
See all Bosch WET 2820 Front Load Washer / Dryer Questions
Bosch WET 2820 Front Load Washer / Dryer Logo
91 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
