Question about Samsung LN-S4692D 46 in. LCD HDTV
I have a sumsung LA40M81BD lcd tv simple problem the tv is always clicking on and off and wont show anything on it. you have to switch it off from the switch on the wall.
  • 517 Answers
Good day!
you have a better chances if you have failing capacitors on the power supply board.
How can you find it?
Just look the actually image of it and see if it is look like leak or bulged on the top.
If you found replaced it with the same type,ratings and value.
Thank you and don't forget to rate my answer.
Posted on May 29, 2011
My phone on and show sumsung J2 but its stops there doesnt do anything and it cannot be switched until i take off the battery
Maybe just a glitch
Remove battery
Wait 10 seconds
Replace battery connect charger
When you have more than 10% try switching on again
Oct 19, 2017 | Cell Phones
Ive connected my vga to vga cable from my desktop pc to the rgb pc input on my lcd tv but it shows no picture. it shows windows loading but wont show my password entry or desktop page
Because your laptop needs it's display setting changing so your second monitor is active.
While on your desktop, right click once and a box will appear, choose "properties" at the bottom.
There you will see another box, choose the "settings" tab at the top right and this will show your display options.
Right click on the number two box and "attach" it.
You may also have to change the size of the display to fit your tv.
Hope this helps
Dec 01, 2013 | LG Televison & Video
Pc not working on tv
If you are using a vga cable to connect to the tv, then you need to make sure the tv source is switched to that source. You also need to make sure that your computer detects your tv. On windows, right click on your desktop and click screen resolution. You then need to click on detect. Your tv should show up here. You can also adjust how you wont to use your tv: mirror the desktop, extend the desktop, etc.
The same process is used for any cable (hdmi, etc.)
Does that answer your question?
Mar 06, 2011 | LG 42LC2D 42 in. LCD HDTV
Power suply led lamp dosent snine, the screen is blank all time?!
yes it always happen to sumsung LCD, but don't you worry, just follow my tips to repair your LCD MOnitor. Click here for the tips.
Aug 09, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung lcd tv is saying low or weak signal when trying to tune it in
you can only use your tv to scan for channels with an antenna or if you have that tv hooked to cable television. use your Directv receiver to scan for channels, if you have an antenna hooked up to it. --------------- click this link for more help http://www.highdefforum.com/directv-forum/77638-new-lcd-tv-d-sd-no-weak-signal.html thaNKS.
Jul 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Sumsung 40'' LCD Hit By Lightning
If it's been the subjest of a lightening strike chances are the saw tooth capacitor is opened and the main fuse. That's a cheap repair even at a good shop... At the very worst they can diagnose the problem for an estimate and that fee is generally worth the money even if that's not the entire problem.
Bill
Dec 04, 2008 | Samsung LW20M21C 20 in. LCD Television
Sound but no pic on a sumsung lcd tv LE46M86BD
if the tv has backlights it's probably the T-con board, if no backlights it's the power supply
Jul 17, 2008 | Televison & Video
Grainy Picture Denon 1740 DVD and Samsung 1080P LA40M81BD
Firstly, you should alter the picture settings on the TV. Most TVs have independant settings for tuner, scart and HDMI, so you may need to do this several times. Once for each.
Excessive contrast and/or sharpness on an LCD causes graininess, particularly around the edges of moving objects.
Check and adjust the following on the TV:
  • Contrast - about 65% max
  • Sharpness - 20%
These settings are a % of maximum, so you may need to work out a value if max is not 100.
Also turn off any contrast enhancements - (Contrast + / Digital
Contrast etc.) dependant on make.
I assume that you are using the upscaling facility of the Denon 1740 via an HDMI lead. If so, disconnect any other connections between the DVD and TV, particularly scart. If the scart is connected the TV will auto-switch to the scart input when you use the DVD, and you will not get the benefit of the high def connection.
This is probably obvious, but make sure the DVD is set to 1080p scaling, and you will need to manually select the HDMI input on the TV.
May 08, 2008 | Televison & Video
Samsung LN-S4692D 46 in. LCD HDTV Logo
251 people viewed this question
Jerry Greenberg
Jerry Greenberg
