Question about Baumatic BW28 Wine Cooler
My Baumatic BW28 wine cooler is making more noise than usual, I assume that this to do with the fan/ can it be replaced?
  • 3 Answers
SOURCE: wine cooler noise
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Jan 28, 2008
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
meBNme
  • 334 Answers
SOURCE: Haier Wine Cooler motor died
Yes, those motors shoudl be pretty standard stock items at any local appliance parts supply house found in the yellow pages.
You might also try lookinmg under "motors and controls" in the yellow pages. If you get it locally like that then you can physically compatre the old one with the new one to make sure it is indeed the same part.
Thats better than an online link with just pictures.
Posted on Jan 27, 2009
SOURCE: Noisy Wine Fridge
I had the same problem, and found it to be as RonLew described. In our case it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Posted on Jun 13, 2009
  • 340 Answers
SOURCE: wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Posted on Jun 17, 2009
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Apr 09, 2014 | Danby DWC283BLS Wine Cooler
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Dec 17, 2011 | Danby DWC283BLS Wine Cooler
My Danby wine cooler fan is making a horrendous noise - it sounds like it's trying to start up and then it gives up. I hav tried tightening the housing screws but this works for a couple of minutes and...
Where is the noise coming from? Check the fan at the back of the upper compartment. They seem to be defective and die after about 3 years (just outside of warranty... how convenient). I'm dealing with the same issue now. (As search on the internet indicates that we're not alone!) When its making that noise, try pressing the back plate around the little fan and see if it changes the noise.
Apr 11, 2011 | Danby DWC283BLS Wine Cooler
My 12 bottle cooler is still cooling OK but it is making a strange loud throbbing or pulsating noise. Is there something I can do to stop this noise?
Mine is too. It\'s the fans they are very cheap and I don\'t think you can find a replacement for them. It\'s the usual stuff made in China that we Americans buy.
Jan 01, 2011 | Wine Enthusiast Silent 12 Bottle Wine...
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
;bw2_nn@hotmail.com
I think it is probably because the body is getting more dust,you can try to clear it by wiping it. Good luck.
Jocelyn.
Best regards.
Jun 15, 2010 | Baumatic BW28 Wine Cooler
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Baumatic BW28 Wine Cooler Logo
127 people viewed this question
Top Baumatic Refrigerators Experts
Sal De
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
