Question about Frigidaire Refrigerators
Hi, I have a frigadaire rle1405 larder fridge that does not get cold,could you please tell me where the defrost timer is on this model. Thank you.
    Master:
  • 414 Answers
Many of the frigidaire units had problems with the defrost termination thermostat located in the freezer compartment. (I have repaired many). It is around 12 dollars
It is clipped to a tube located in behind the freezer back panel. take out the
plastic vent and motor, unplug the motor (very carefully to prevent pulling out the
leads) the defrost termination thermostat has two leads and is clipped onto a
tube. The replacement will have heat shrink and wire nuts, but I often use
**** splices under heat shrink tubing to ensure no moisture gets into the connections and a dab of silicone at the ends of the heat shrink. Make sure the "colder" knob
is set in the middle on the vent stack as this will cause problems if set to "colder".
I have only seen one defective defrost timer (incorrectly assembled) which caused the
gear to stick in one position. You can manually rotate the timer to check operation with
a screwdriver in the access hole on the bottom of the temp control panel. (oddly the new timers are of a different make if it has failed). Unplug unit before servicing.
Posted on May 29, 2011
Auto defrost failure
What is the model number? You can get the part for cheap and replace it.
Jul 10, 2013 | Refrigerators
Liebherr KBES 3650 - too warm in main fridge compartment. Hi the main fridge compartment of this larder fridge warmer the it should be (milk does not taste as cold as it should). The temp...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Liebherr KBES3650 Stainless Steel...
Water collecting in the container.
It does sound like it might be the recent excess of humidity we've been having. Once dryer weather comes, see if it's still happening. It does take a while for cold water to evaporate from just the heat of the fan blowing over the compressor.
Only other thing i can think of is, it's defrosting more often than it should be, meaning you may have a bad defrost timer. It should only be defrosting once a day. But I'd give it time before ripping it apart.
Jul 16, 2010 | Whirlpool Refrigerators
KitchenAid fridge model #EE4412201, freezer is NOT defrosting. Air tower iced up a little, freezer floor all ice. water in back of fridge. Freezer is cold, fridge isn't. I cleaned the freezer, took the...
try a new defrost timer. or new kit defros timer defrost terminator and heater. tfound the timer rotate, open the freezer. if you hear a noise like ICE BREAKING. your onli problem is the timer. really important after repair your fridge. allow at least 24 hr for defost the whole evap. REALLY IMPORTANT
Mar 31, 2010 | Refrigerators
I have an upright Premium larder fridge,about 18/12 old. It keeps freezing everything. We have 'defrosted' it more than once but it keeps happening. Any ideas?
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 03, 2009 | Liebherr KDPes 3142 Premium
Fitted tall larder fridge freezing up on the back wall what is the problem and how do l sort.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 30, 2009 | Refrigerators
Hi I have a whirlpool fridge the buttom don't stay cold an
This is most likely the defrost timer or Adaptive defrost system. I will need your model number to be able to tell you what your model has. The places to locate the model numbers are in the photo be.if a Sears model the numbers will look like this for example 512.3645897
Thanks, and let me know, Sea Breeze
Or just click
HERE
and enter your model number.
Aug 06, 2009 | Refrigerators
Refrigerators Logo
228 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
