Hi , my asus p5kpl-cm is freezing constantly like after every 10-15 minutes the whole system freezes , even freezes in bios . i checked my ram , cpu , psu , gpu and hdd on my friends pc all are working fine. i am very depressed i never overclocked it thanks
SOURCE: Can't install a driver
i've lost my driver cd for my asus wl -167g, can i download it for free?
Posted on Jul 08, 2008
  • 10 Answers
SOURCE: processor load on biostar m/b
IT seems no problem with your specification, but only one thing less in this criteria. What inch does your monitor? This must be match with the specification of your VGA Card, The more resolution you can get the best performance of this VGA card you can achieve, try to higher the resolution of your monitor , don't only use 1024 x 768 , but try another higher resolution. The VGA itself cannot reduce the system perfomance, because your vga card has GPU (This VGA card has his own processor and memory) just like mini computer inside your main computer.Hope this things can solve your problem, don't forget to vote
Posted on Aug 01, 2008
  • 13 Answers
SOURCE: DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
Posted on Nov 06, 2008
SOURCE: ASUS P5KPL-CM Bios Problem with Core2Duo 2.8 Ghz Processor.
I recommend going to this site and getting the latest Bios for the board.
http://support.asus.com/download/download.aspx?SLanguage=en-us
I don't know your expertise with computers but it will require you downloading their Bios boot disk utility and creating a boot disk. then copy the Bios file to the same disk. When you boot it up it will guide you through the Bios flash process.
Be aware that you can completely kill the Bios if it has a problem during the flashing so only do it if you are positive you can get through it.
Alternately if you can push the F1 and get into the OS the Motherboard utility disk should have an updater you can use from inside windows.
Posted on May 04, 2009
  • 81 Answers
SOURCE: ASUS P4P2E-X 1 long beep that continue without end
hi,
I think One long beep that continue means RAM problem , Ram Can May be dead or faulty, check on other ram.
I hope that this has been very helpful for you
Posted on Nov 16, 2009
I am using asus p5kpl-am se motherboard with c2d 2.93, 4gb ddr2 ram, 1gb zotac geforce 9800 series pci card with xp sp3 os. When i check properties from my computer the memory ram is showing only 3gb...
ASUS P5KPL-AM SE supports up to 4GB RAM. I think that 1GB RAM is shared with the PCI Express Graphic Card.
For further details about your CPU and Graphic processor, I suggest that you download two small free utilities
Click here to download CPUz
Click here to download GPUz
These usefull utilities will provide you all the additional details.
Good Luck!
CreativeTECH
Nov 25, 2010 | ASUS P5KPL-AM SE Motherboard
I HAVE ASUS P5KPL-AM IN MOTHER BOARD MY SYSTEM IS ON BUT I DONT FIND DISPLAY IN MONITOR. MY RAM IS OK, MY PROCESSOR IS OK BUT I DONT FIND DISPLAY ON MY MONITOR .
if you have your monitor light flashing or the cpu fan is working when you on the system try this,
you just need to load the BIOS to its defaults, to do this you need to open the CPU case, unscrew the two screws on the left side of your cabinet, on the motherboard you can see a small button sized battery, remove it and after one minute replace it into its position.
close the cabinet and start the computer it'll work fine....
Sep 06, 2010 | ASUS P5KPL-AM SE Motherboard
After assembling my new asus P5KPL-CM MotherBoard with Core2Duo 2.8 GHz Processor, I get a msg on post; 'unknown cpu detected,bios update is required to unleash its full power' apart from now having to hit...
http://www.asus.com/product.aspx?P_ID=6nnVb6RBxd7PhGmt#
If the link does not work use the search feature for the P5KPL-CM the go to downloads.. it is rather easy to do and can be done on the boot up through easy flash utilities from a USB Jumpdrive
Select the Operating system you are using and Download the newest bios. i had a similar problem with my CPU untill I upgraded the BIOS now it is running like a champ.
Sep 03, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
P5kpl-cm with intel pentium e6300 reboot cycle !!!
first refresh ram & clean ram slot, then check cpu fan properly working or not, if you do this then your machine working fine.
Mar 16, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Same problem
You need to flash the bios to a newer version for this cpu to be supported by your motherboard. Your descriprtion says asus so go to www.asus.com; click on the support link; lookup your specific board model #; select the operating system you are running. Download the latest bios file and follow the directions on the download site for proper flashing. Once you have flashed the bios everything should identify properly and allow you to continue setup. Hope this helps.
Jul 19, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
May 04, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
