Question about Samsung Televison & Video
HDMI CABLE CONNECTION WILL NOT WORK, ONLY WORKS WITH AUDIO-ANALOG CABLE. I HAVE A SONY BRAVIA TV
  • 517 Answers
Good day!
You TV is not set to cable only air or aerial.
Try to go to the menu and enter settings and find the antenna option choose cable.
Thank you
Posted on May 29, 2011
Channel cable hdmi
You will need to go into the tv's "settings" menu and change the input label from "Skip" to anything else that best describes the device that is attached to it.
Good Luck!!
Rich Lilja
Dec 24, 2013 | Sony BRAVIA KDL-23S2000 23" LCD TV
Apple tv and Sony Bravia 26S2030
HDMI contains both video, color and audio all in one cable----audio connection with it is not without issues.
May 14, 2012 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Hi, Just bought a 26" sony bravia tv. I don't use cable or satillite. I just need to find out what kind of cable I need to connect my panasonic DVD player to the TV and which port do I plug it into?
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hdmi connection for camcorder to hdtv does not work.
If i am to understand you correctly, you are are connecting a mini-HDMI adapter to the TV, and another adapter to the camera, then connecting the two adapters together.. i believe this may be an issue..
Too many adapters can actually cause signal issues, especially when converting a digital signal to analog, then back to digital, or vice versa.
Check to see if the manufacturer of your camera has an adapter to go directly from the camera output source to your TV's input.
Cam > adapter > TV = Correct
Cam > adapter > adapter2 > TV = Signal degridation
May 28, 2009 | Acer Aspire m5640 PC Desktop
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No audio through hdmi cables from tv...Please help!
this is a relative defect:
the HDMI connector can hold digital audio but analog audio cannot be decoded in this step. HDMI most of the time has a couple of connectors besides it that it is a couple of regular RCA connectors right and left channels. has to be connected to listen this kind of audio. some signals in now days are totally digital but still some signals that have regular analog audio (as the old fashion days)
Apr 15, 2009 | Televison & Video
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony bravia intermittent sound
Yep, same problem with mine. After many trial fixes, I discovered that it's the HDMI connection. I tried two different new HDMI cables in two of HDMI ports on the TV, but still got intermittent sound. The only way I solved it was going to component cables (RGB) with a separate audio cable. Works great now. Other Web sites say that HDMI connections do not always electronically "handshake" well between devices. Not sure how this HDMI problem can be permanently fixed, but using the component connection works fine.
Feb 20, 2008 | Sony BRAVIA KDL52XBR2 Television
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Televison & Video Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
