Question about Husqvarna Garden
The gap between the armiture and flywheel on a 13hp vanguard motor
  • 605 Answers
Hi, 8 thou. Hope this helps, regards Phil.
Posted on May 29, 2011
My riding mower won't start, new starter spark plug and fuel filter. Now what?
You did not post any information about the motor. There is a specific gap between the magneto and the flywheel and also the flywheel has a woodruff key to make sure the timing is correct. Check for spark, check gap on magneto and check magneto if you don't have spark.
Apr 27, 2017 | Garden
Spark plug gap settings chart and points gap
What make of motor and horsepower,plugs normally 25thou inches.evinrude Johnson below 40hp points 20thou inches,55hp and up 10thou.to take flywheel off you need a puller
Aug 24, 2014 | Boating
What is the size of gap between spark plug and armiture for 2005 aveo?
If its the 1.6 its .039 - .043 inches. Good-Day! (spark plug gap )
Jul 16, 2014 | 2005 Chevrolet Aveo
Greenfiled ride mower 13hp
the mesh cover should have screws in it or the center cup holds it in place. youll have to remove center nut or bolt to get flywheel off
May 26, 2014 | Mtd Garden
Not getting spark to plug on eagerbeaver 2014
Jeffuxum:
The magneto is probably where the problem is. You'll need to pull the cover off of the motor and check the gap between the magneto and the flywheel. If the bolts holding the magneto have vibrated loose, the gap between the magneto and the flywheel will be incorrect. While you have the motor cover off, check the wiring to make sure you don't have a short in your ignition wiring and clean the air filter. I don't remember what the gap is between the flywheel and magneto, but .010 In. sounds familiar. Both legs of the magneto should be the same distance from the flywheel and they must not touch the flywheel at any point. I have used a matchbook cover between the flywheel and magneto while I tightened the magneto retention screws and it worked.
Jan 18, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Set timing on tecumseh 5-H.P. gasoline engine model H50-65371 J
Indications that the motor is out of time: jerks the rope out of your hand when trying to start, pops out the carb, runs but has no power and sounds 'off'.
When assembling the motor a dot on the cam gear and a dot on the crank gear need to be lined up.
If the motor has run correctly before the problem and has not been disassembled then the problem is likely external.
There are no actual timing adjustments. The flywheel key holds the flywheel in the correct position. If it is sheared or partially sheared the timing will be off. Check the flywheel key by removing the flywheel and visually inspecting the flywheel key; replace if not 100%. On assembly be sure the flywheel nut is tight or it will shear the key (again), then set the armature air gap ( gap between ignition module and flywheel magnet) to .020
On older motors the points gap can affect timing also but I dont believe your model has points. The points gap is also .020
Nov 19, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Need to know flywheel gap18 horse briggs
The flywheel gap on most Briggs motors is between 25 and 35 thou. the easiest way I have found to set them is if you have a pack of paper matces tear off the cover of the matches and the cardboard the cover is made out of is a perfect dimmnsion to set flywheel gaps and points and being cardboard it does not get effected by the magnets on the flywheel. Hope this Helps Don
Nov 09, 2009 | Mtd Garden
No spark
Replace the coil make sure when insalling new one gap between flywheel and armiture .500 mm
Aug 12, 2009 | Tecumseh Garden
What is the gap setting for a 13hp honda motor
20 Thousands will work. If it does not, the you have other issues.
Apr 18, 2009 | Spark Plugs BR4HS Plug 10/BX #3322
Garden Logo
46 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
