Question about Kodak Office Equipment & Supplies
Need instructions how do I clean the ink heads of the ESP3250PP ALL-IN-ONE
  • 1,188 Answers
For ESP 3250, 5250, 5210, Office 2150, 2170, 6150, 7250, 9250, C110, C310, and C315 printers:
  1. Press Home on the printer control panel.
  2. Press the down arrow button until Maintenance is selected, then press OK.
  3. Press the down arrow until Clean Printhead is selected, then press OK.
Posted on May 29, 2011
How to manually unlock printer head position that is currently stuck in print head cleaning area.
if you see inside the printer there is a white gear in the left side . try to turn it front or back and move the cartridge
Feb 18, 2016 | Canon PIXMA Office Equipment & Supplies
Cleaning head and nozzles
Cleaning the Print Head
r_bullet.gifUsing the Head Cleaning utility
r_bullet.gifUsing the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
  • Print head cleaning uses both color and black inks. To avoid wasting ink, clean the print head only if the copy quality drops (for example, blurred printout, incorrect or missing color.)
  • Use the nozzle check first to confirm that the print head needs to be cleaned. This saves ink.
  • When the Error light is on and a message appears on the LCD panel to prompt you to replace the ink cartridge or to indicate the ink is low, you cannot clean the print head. In this case, replace the appropriate ink cartridge first.
Refer to the appropriate section below to use the Head Cleaning utility.
For Windows
Follow the steps below to clean the print head using the Head Cleaning utility.
r_1.gifMake sure that A4 or Letter size paper is loaded in the sheet feeder.
r_2.gifMake sure that this product is on and the ! Error light is off.
r_3.gifAccess the printer software.r_arrow2.gifAccessing the Printer Software for Windows
r_4.gifClick the Maintenance tab, then click the Head Cleaning button.
r_5.gifFollow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
r_space.gifr_caut.gifCaution:r_space.gifr_space.gifNever turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
r_6.gifWhen Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
  • If the copy quality has not improved after repeating this procedure four or five times, turn this product off and leave it alone overnight. Then, perform the nozzle check again and repeat the head cleaning if necessary.
  • If the copy quality still has not improved, one or both of your ink cartridges may be old or damaged and may need to be replaced. To replace an ink cartridge before it is empty, see Replacing an Ink Cartridge. If the copy quality remains a problem after replacing the ink cartridges, contact your dealer.
  • To maintain good copy quality, we recommend copying a few pages at least once every month.
Apr 14, 2013 | Epson Stylus CX6400 All-In-One InkJet...
How do I clean the ink heads of the ESP3250PP ALL-IN-ONE
Thanks!!
EJ Kudelka
May 29, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
No Printed documents
Have you performed a print head cleaning? If not, follow the instructions below:
1) Press <Menu> on the panel repeatedly until [Maintenance] appears on the display
2) Press left or right arrow buttons until the cleaning setting you want appears, either [Head Cleaning] or [Head Refreshing]
3) Press the <OK> button.
Note: Head cleaning should be attempted first, and may need to be done more than once. Examine the results of the test page.
Head refreshing is more aggressive, uses more ink and should only be performed when necessary (ie. when multiple head cleanings failed to solve your print problem).
Dec 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Won't reconize new ink cartridge rx680 printer
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs???
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
My printer heads need cleaning
Go into your printer software by clicking on the required proram in the programs menu select Clean Print Heads and off you go
If they are really bad you may need to buy a Cleaning Cartridge Set
Sep 15, 2009 | Acer Aspire 5610-4648 Notebook
Print is not solid enough to read
Either head need cleaning or the ink is running low.
You have to clean the print head manually. The head is on the ink Cartridge.
Look in your manual for a picture. A picture may also be on your computer instruction on how to change a cartridge.
A cleaning solution is available to clean the head. I get mine when I buy ink to refill.
I hope this help you
Mar 13, 2009 | Epson Stylus C60 InkJet Printer
Continuous aqua/turquoise color even with new cartridge
hey Karyn. The problem that I have experienced with printers with the same problem is a dirty head. Get the instructions on the printer and it will tell you how to clean the head. If after cleaning, still does it then you need to purchase a new head for the machine. Dont be afraid to tear into it. printers are pretty simple. Ink and ink head. If it prints at all it seems to be a dirty head. or worn out. Watch out using ink refills or off brands. Some inks are not very good quality ink and will ruin the head and void the warranty. Use the ink that the machine requests. Staples or Office Depot carries several types of printer heads. Good luck.
Sep 04, 2006 | Epson PictureMate InkJet Photo Printer
896 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
