Question about HP Deskjet D2360 InkJet Printer
It won't print, says 'communication error' and 'help with printer lights'
    Novelist:
  • 132 Answers
1. Disconnect the Printer cable
2. Uninstall the HP Printer Driver
3. Click the Start icon, Computer, go to the Tools menu, select Folders Options, go to the View tab and set Hidden Files and folders as Show hidden files and folders.
4. Navigate to directory c:\windows\system32\spool\drivers\
5. Delete the w32x86 Folder. If cannot be deleted download the printer patch from the hp website
6. Restart the computer with the printer cable disconnected
7. Install the HP printer driver and it will ask the printer cable to be plugged in
8. That is the time that we will be plugging in the printer cable
9. By this time the printer is communicating to the computer by now
Hope this helps
Posted on May 29, 2011
Won't print. Power is on, cable attached, computer says it is going to print. Says there is no 2 way communication between the printer and ?
You must firmly insert the cables that connects b/w PC and printer or buy new connector. Or, you may reinstall the driver..
Oct 20, 2012 | HP Deskjet D4360 InkJet Printer
"online" light flashes, but labels don't print
Check that you are using the correct escape characters.
in printerparameter check that you are on auto
else check in the driver you are using esc LF Nul or {'} characters.
last if in serial mode check the communication parameters
default 9600,n,8,1 (no partity 1 stop bit, 8 data bits)
Jul 30, 2012 | Toshiba TEC B-572 Printer
Lexmark X1190 problem communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
Printer won't download application list for scanning
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Sep 28, 2011 | Lexmark Interpret S405 Wireless All-in-One...
"Communication Not Available" message is displayed
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
Hi - my x4550 lexmark printer wont print, can you help?
If your printer won't print when you're making a copy using the Copy button on the operator panel, it could be due to your ink cartridges. Try to re-seat your ink cartridges into the printer and make sure they are properly seated.
If you're not able to print from your computer, it could be a communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
You may refer to this article for Wi-Fi connection issues: How to identify a Wireless Communication Problem and Resolution Tips
Aug 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
Printer suddenly will not communicate with the computer. Tried unplugging both wall plug and usb plug. Printer can print but only test page. Tried to uninstall, but computer won't allow me, gives error...
Have you tried rebooting your PC? Do you see a printer Icon in the taskbar (right corner) if so click on it and you may see several que's and the printer is bound up, so-to-speak. The reason your able to do a test print is because that command bypasses any que's in memory. Turn your printer power off, then reboot your PC. Onces its booted up, turn on your printer. This will clear any que's and your printer should communicate again.
Let me know if this help you.
Thank you
Jul 04, 2011 | Computers & Internet
Keeps pausing job won't print. also won't scan... "can't load application" scans only to flashdrive.
Your firewall could be blocking some printer communications. Make sure to allow full access to all Lexmark and printer communications in the program rules/permissions for your firewall. For more information on how to configure the settings for your firewall, visit the Lexmark website at http://bit.ly/iNwkNs.
May 14, 2011 | Lexmark X4650 InkJet Printer
HP Deskjet D2360 InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
