Dorgem Failed to connect to device!
Samsung corby 2 (s3850) wifi connection. It can't connect to the wifi. It always end up DNS failed.
Verify that you have the correct security protocol and password. Are you sure the router has a good connection to the Internet service provider? If it doesn't, you'll get a DNS failed message on every device connected to the router.
Jan 16, 2012 | Samsung GT S3850 Corby II
I have an ACER Crystal Eye integrated webcam that does not work. Checks of software and driver upgrades state I have the latest version. Check on device manager and webcam error code 10 appears. Solution...
found this solution online
Want to know what worked for me? Acer drivers.
I found this driver: Acer Extensa 5210 Chicony Webcam Driver 5.7
(I have also mirrored the file here.)
Here are the exact steps I took.
1. Downloaded the file.
2. Unzipped it to a folder on my desktop.
3. Ran the "Setup.exe" file in the folder that got unzipped.
4. Went through the installer until it got to the end and then let it restart my computer.
5. Waited for my computer to restart.
6. It popped up something saying it was installing the drivers for my webcam. Waited until it was done.
7. Opened the Control Panel.
8. Opened the Device Manager.
9. Find my webcam under "Imaging Devices". I noticed it was listed as "HP Pavilion Webcam" despite having just installed the Acer drivers.
10. Right-clicked on my webcam and chose "Update Driver Software..."
11. Chose "Browse my computer for driver software"
12. Chose "Let me pick from a list of device drivers on my computer"
13. Unchecked the "Show compatible hardware" checkbox.
14. Scrolled down to the Chicony manufacturer.
15. Chose the "Acer Crystal Eye webcam.
16. Told it to install anyway when it asked me a question about installing that driver.
17. Waited for the driver to be installed.
18. Noted that my webcam was now listed as an Acer Crystal Eye webcam in Device Manager.
And that was it. It appears to work totally fine now! Again, I have my fingers crossed that it won't suddenly break again, but so far so good.
Forgot to note: This is on a DV6000T running Windows Vista 32-Bit Home Premium.
And here's proof: smile.gif
I took that with Dorgem, an excellent, free, open source webcam application.
Oct 30, 2010 | Computers & Internet
My phone samsung gt-s5233w cannot connect through wifi connection..everytime i try to connect the device, "dns failed" is always displayed.
my phone samsung gt-s5233w cannot connect through wifi connection..everytime i try to connect the device, "dns failed" is always displayed
Aug 04, 2010 | Samsung Star GT-S5233 Cell Phone
My V450 Nano Cordless Laser Mouse for Notebooks aint working the green light is on but it doesn't get recognize by may laptop
Q: Troubleshooting: Basic Mouse/Trackball Problems trnsp.gif This article covers some common reasons why a Logitech mouse may cease to function.
trnsp.gif This article applies to the following products:
All Logitech mice/trackballs
Cause:
There are a number of reasons why a mouse or trackball may suddenly stop working. These include the following:
  • defective hardware
  • system configuration changes
  • wireless detection issues
  • hardware connection failures
Solution:
It is possible that the mouse or trackball has failed. A failed unit can be described as a product that works for a period of time then suddenly stops working. Verify that you have not made any changes to the system that might coincide with the failure of the product. For example, if you moved the connection of the device to another port to add another device to the system or if you added new software or made other system changes. Also, verify the device has not become disconnected from the system by checking to see the device is correctly connected. Once you have verified the above potential causes for failure, proceed to the following steps.
1. Wireless Detection Issues
If you are using a wireless mouse or trackball, you should first check to see if you have a connection issue. Please see Knowledge Base article 970 for information on diagnosing and resolving detection issues.
2. Port Connection Issues
If you have concluded that the issue is not due to a detection issue and the pointing device has just stopped working, try the device in another port. If you were using it on the PS/2 port, try moving it to the USB port if you mouse supports it. If you have another USB port, try that other port. If you were connected through a hub, try connecting directly to the system ports to verify the hub has not failed.
3. If the device doesn't work on a second port, try it on a second system, if possible. If it fails on a second system, then the device probably is defective. You may also want to try a second mouse in the same port that the failed mouse was using.
4. If the second mouse does not function in the same port, verify the system port has not failed. Contact the system manufacture for more information on the status of the system port.
5. If either the mouse fails on a second system or the second mouse works in the same port, then you know the Logitech mouse is defective. If this is the case, please contact to inquire about a warranty replacement.
Answer ID 3997
Created 2006-06-13 01:54:48
Updated 2009-06-03 04:28:23
Jul 18, 2010 | Logitech V450 Nano Cordless Laser Mouse
Creation of the video preview failed please check
I Have checked the device connection , it is o.k
Oct 31, 2009 | Creative Labs WebCam Live!
How to use compaq 510 notebook pc webcam without im service
HP provides Cyberlink Youcam software free with laptop factory settings
Click Start button
Type youcam
click the exe file
view, capture image or video, save, etc.,
If you cant see any file download this software
http://download.cnet.com/Breeze-Light-Edition/3000-13632_4-10588374.html
http://download.cnet.com/Webcam-Capture/3000-2348_4-10671921.html
http://download.cnet.com/Dorgem/3000-2348_4-10525570.html
Oct 10, 2009 | HP Computers & Internet
I have the same Issue
Could be a device has failed. Unplug all devices from the computer. Hard drive, cd drive etc.....anything that uses power. the only thing drawing power should be the motherboard. Try the power. If it comes up then power down and plug in the devices one at a time power back up and repeat for each device. if it doesn't come up then the last device connected may have failed. If the power still doesn't come up then pull all the boards and memory and try again connecting one board at a time. Still no, pull the cmos battery and check it. Still no power check the power switch and connections. Try to start the computer by shorting across the power switch buttons. Still no power...make sure it's plugged in.
Jul 30, 2009 | Gateway GT4022 PC Desktop
My player displays a message
Connect player to pc and power, restart player while holding the volume + key, as soon as the player shuts off, press and hold the volume - key, your device manager will pop up and tell you the player needs repair, let it do so.
Jul 18, 2009 | Philips GoGear HDD6330 MP3 Player
Can't find webcam control.
Go to
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-001&h_lang=en&h_cc=us&h_product=3832468&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
Or if that link doesn't work:
http://welcome.hp.com/country/us/en/support.html
and search for your Mini 1000
The exact model # should be on the bottom of your laptop. On the support site you should be able to find the webcam driver, there you can reinstall it.
If you want some to 'capture' images from your webcam, try: http://dorgem.sourceforge.net/
Feb 27, 2009 | HP Mini 1000 Netbook
Using Wing for internet through macbook pro?
You can connect and synchronize your device with the pc using bluetooth. ON your device tap
1)Start-Program-Active Sync
2) Make sure that Bluetooth on both your device & the computer are turned on and set to visible mode.
3)Tap MENU-CONNECT VIA BLUETOOTH.
goodluck
Jul 25, 2007 | T-Mobile Wing™ Smartphone
Computers & Internet Logo
1,110 people viewed this question
David Payne
David Payne
