Question about Rinnai Heating & Cooling
Error 90 Rinnai Ultima 11 space heater - Rinnai Heating & Cooling
Therinnaiguy
  • 1420 Answers
SOURCE: rinnai space heater
Help us out by giving us a make and model number.
Posted on Oct 25, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: error code 11 on my rinnai
A code 11 also means that it might not be getting any gas. On thr right side of the unit you will find a small door. open it up and make sure the valve is in the open position. If it is, you should contact your gas company to come and diagnose what is going on. The Rinnai is not a do it yourself fix it type of heater.
Posted on Nov 07, 2007
  • 120 Answers
SOURCE: Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Posted on Jul 21, 2010
  • 120 Answers
SOURCE: Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Posted on Jul 30, 2010
  • 120 Answers
SOURCE: Heater goes out after 20min error code 12 appears
Definately a gas supply problem. If it was an overheat you would get a different code. Error code 12 meant a flame was there but then went out. The code 11 meant tried to light but no flame sensed. Error code 12 on heaters and Infinites is nearly always a fault on the gas regulator at the bottles. Sure I recognise your company name from up in Queensland. As you might know we hae had problems with an oily residue in some regulators for ages. I am recommending going away from two stage regs and spliting them up with a seperate first stage and then a second stage. Bit more expensive by zero call backs.
Error code h
Error code 11 is ignition failure
Error code H is over heat
May 28, 2016 | Rinnai Heating & Cooling
Getting an error code of 11
Error Code 11 indicates an ignition failure. Check that the gas supply is turned ON. Switch the heater to STANDBY and the ON again. If the burner doesn't light or you continue to have a problem contact your Rinnai dealer.
Hope this helps you and thanks for choosing FixYa. Cheers ...
Sep 20, 2011 | Rinnai Vent Free Gas Heater/
A buzzing noise is coming from the back of the Ultima II Flued Space Heater - rinnai only 4 months old.
Likely be a tranformer but either way contact Rinnai direct, you have full parts and labour warranty if only 4 months old. They will send a service agent out.
Sep 16, 2010 | Heating & Cooling
Want to replace old rinnai 2000 with ultima
I have changed a 2001 Consule to an Ultima Consule once and just had to raise it up 50mm using a plinth. I made one myself using some nice tiles and hardwood face that pleased the customer. I've tried to search through my manuals for a 2000 to double check that the flue spigot is the same width and depth but couldn't find one.
All I can say is my swap worked ok with the plinth. Not sure how a 4" one will look though? Double check measurements on the old 2000 and you should be ok.
Only other way would be to cut out a larger hole in the wall to access the flue, fabricate an extension to the twin wall down pipe and actually drop the spigot opening. Sounds a bit more hassle, hard to say without actually seeing the thing. Hope it turns out ok and this limited advice was worth it.
Aug 02, 2010 | Heating & Cooling
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Mar 22, 2009 | Rinnai Digital Remote Water Heater Control...
No hot water
An error code of 11 equals no ignition. Check gas supply, sparker, flame rod, burner and ground.
Nov 27, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai 1004 error code 11
I had this problem and oops, the gas intake was closed. check the door on the right side of the unit, and make sure the valve is turned to "open" .... here's the link for the online manual if you want it: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf
Oct 04, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Convector 406TR
press and hold the child lock button until it beeps...
Jul 02, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error code 11 on my rinnai
Nov 06, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
251 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
