Question about Home
Triton Enrich shower will not heat up, is there a reset button inside.
4 Suggested Answers
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
peterrance19
  • 399 Answers
SOURCE: triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Posted on Nov 15, 2009
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Triton Ivory 2, 8.5 kw electric shower flow has been getting porgressively weaker. Mains pressure if fine. Shower head is clean.
there could be a blockage on cold water connection which may have a filter which needs cleaning or the heating tank inside the shower could be blocked with limescale try cleaning the filter you cvould also check the shower hose for blockages or kinks
Dec 09, 2010 | Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
Triton jade 2 shower not generating sufficient heat
Nov 11, 2009 | Home
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
Triton opal electric shower overflow pipe
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
Nov 19, 2008 | Home
Home Logo
265 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
