Question about Sony SLV-SE830 VHS VCR
I have a sony SLV SE830 the sound plays but the picture doesn't it just shows on the screen as white fuzzy horizontal lines. Does this mean the heads are broken? Thankyou
  • 1694 Answers
SOURCE: Picture went black
Check vertical B+ and replace vertical output IC.......Let me know if you need more help.................T.
Posted on Dec 11, 2007
  • 163 Answers
SOURCE: Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
ken@ikenfixit.com
Posted on Jan 22, 2008
  • 2336 Answers
SOURCE: I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Posted on Jan 25, 2008
dodgecharger
  • 254 Answers
SOURCE: no picture
I assume this symptom appears when attempting to play a tape? If the picture is mostly snow, VCR may need video head cleaning. To do this, take the top cover off- You will note a cylindrical shiny aluminum drum- the actual heads are at the lower edge of this rotating drum.
Anyway, use a lint free cloth or special wipe moistened with rubbing alcohol, or product specifically made for such, carefully cleaning those heads as well as the drum itself. Occasionally, it may take 2 or 3 cleanings.
If the VCR has lots of hours, or abrasive head cleaners have been used, the head could be worn out. If so, toss the rig and purchase a new one. Head replacement is non-economical unless you have a high end machine.
Posted on Jun 12, 2008
mediarich
  • 188 Answers
SOURCE: Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Posted on Sep 18, 2008
Sony SLV-ED818 black and white picture
Is the TV a USA model? In which case it will use the NTSC system of colour and not the PAL one. You will need to check if the TV can be switch to PAL system for DVD or if the DVD can output it as NTSC. Or you need a convertor box.
Jan 23, 2013 | Sony SLV-ED818 VHS VCR
Fuzzy Display in bottom 2/3 of screen
Power supply is probably going out. Not likely the video card in this case.
Nov 18, 2012 | Viore " 24"" Class - LED - 1080p - 60Hz -...
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
Hi there, Having some trouble with the Sony SLV-SE830 VHS VCR. It should just work once the power is switched on and the SCART lead is connected to the back of the TV and the AV channel is set to the...
If you tv has more than one SCART connector.. ensure you have the cable plugged into the proper one.
Not sure what the problem is.. if you have a modern bidirecitonal SCART cable properly connected.. you should be able to view and hear the tape as it plays.. assuming the machine is in good condition.
Of course if you want to record a program other than the one you are watching you will ned to supply an independent broadcast signal to the VCR.. and yes you may have to program the tuner on the VCR if you want to record.
However if you simply wish to view tapes.. you shoud be set to use the machine as connected.
Best of Luck!
Apr 08, 2011 | Sony SLV-SE830 VHS VCR
Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
Mar 29, 2007 | Sony SLV-D550P DVD Player/VCR
Sony SLV-SE830 VHS VCR Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
