Question about Olympus Cameras
Battery do not fully charge - Olympus Cameras
    President:
  • 1,607 Answers
There is no way to fix a battery. Time to buy a new one.
Thanks for using fixya!
Posted on May 29, 2011
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
Pedego hub motor jumped and then no power. Fully charged battery and have lights showing fully charged battery.
Please give us a call so we can fix the issue! (800) 646-8604
Thank you,
Pedego Team
Oct 01, 2012 | Motorcycles
I have a Rascal 305. How long should built-in charger run to fully charge batteries. Mine only charges about one hour at 3.5 amps (on meter on back) before shutting off. What should charging current be,...
moleman If the batteries are fully depleted then the on-board charger will not pick them up and charge them to full strength. It is not designed to charge very low batteries. If the batteries stayed fully depleted for a period of time you will have to replace both of them. You should never fully discharge your batteries. The battery level gauge on your chair should be used to determine when to charge if it is the red recharge overnite. Get into the habit of recharging overnite if you use the chair daily. Always store the chair fully charged and if not used weekly charge once a week. Never leave the charged plugged in more than 18 hours. The chair only operates on about a 5-6 volt range from about 21-26 volts. If you are in the red the voltage is down to about 20-21 volts. Hope this helps you
Sep 29, 2010 | Health & Beauty
After charging my MP3 player it appears fully charged but it will only play for about an hour and the battery runs down. i have recharged it again, same thing. now what?
The very first time you charge your battery YOU MUST CHARGE IT FULLY!!! If you didn't, that is probably the problem.
Also, even if you charge the player for just a couple of minutes it will APPEAR to have a fully charged battery when it actually doesn't.
Most portable media devices require at least 20 minutes to an hour to fully charge whether the screen shows that it is fully charged or not.
Jun 30, 2010 | SanDisk Sansa e250 MP3 Player
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Battery will not fully or will not charge
Whenever you first purchase a device you must charge the phone fully otherwise if you charge it partially an then use it it will never charge good. You may need new battery see if youe warranty covers it \. If you are within 30 days of purchase you can exchange it at no cost!
Sep 04, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Palm Charging
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Cameras Logo
148 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
