Question about Mercury Computers & Internet
I have mercury mother board and exter usb pinsocket (usb 3 and usb 4) there are some notes besides but not understandable. can you guide me to connect them?
2 Suggested Answers
  • 7 Answers
SOURCE: i have mercury mother board
Hi Rajen samani!
Most mercury motherboards with a nine pin front panel connection use the following configuration.
You may want to double check to make sure that your motherboard follows this configuration. Just go to http://www.mercury-pc.com/downloads.php, enter your model number, and you'll be able to download the manual for your board. The jumper configuration should be in a section labeled "Front Panel Connection" or something similar.
Hope that Helps!
Posted on Mar 07, 2011
It took a lightening strike. is there a power reset on the unit?
There are two ways to do a reset on *********** board.
CMOS Jumper
1. Open your computer.
2. Look for a mother board jumper labeled as JBAT1, CLR CMOS, CLR TC or just a push button for a mid to high-end mobo. it should be placed near the BIOS or beside the CMOS battery.
3. It should look like this, as you can see there is a white triangle indicator and a number 3. The pins 1,2 are shorted, try to removed the pin and short pins 2,3.
4. Now put the jumper back to pins 1 and 2, it's all done. now you can go to bios and load defaults before you can change values.
CMOS Battery
1. Look for a 3v battery on the mother board.
2. Press the lock downward to remove the battery.
3. After removing the battery re install the battery. by doing this you have successfully cleared BIOS settings.
NOTE: 1. Check the fuse of your AVR if it is busted. replace the busted fuse with same rating.
2. Check your power supply. If it's dead try to fix it by replacing the fuse but it will require soldering tool and skills. 3. Your computer might still work but in my case the usb ports can only read flash drives after the lightning and the network interface card is busted.
Hopefully this information helps.
Thank you for using FixYa.
Aug 14, 2011 | Computers & Internet
I have mercury mother board and its having nine pinsocket for reset switch,power switch,hd led ,etc but i dont know their proper connections. there are some nos besides but not understandable . can you...
Hi Rajen samani!
Hope that Helps!
Mar 07, 2011 | Mercury Computers & Internet
Pen drive not recognise and show message thie is high speed 2.0 usb
we should thik 1st softwere which we can see on system manager usb port. is installor not.2/ check fornt and back port is work or not. if bord port damage we can put another usb card in mother board pci slot. 3/look in bios usb port is enable or disable
Oct 14, 2009 | Mercury P4VM800M7 Motherboard
Where to find mother board driver for mercury 810e mother board ....
You will find the driver for your motherboard at
put the model 810e in the "Search by Model". You will have to know which of the 3 variations you have according the the next page of the search.
May 12, 2009 | Computers & Internet
Please tell - the mercury mother board p1865d7 - how we connect the reset button and start button on mother board. please send the diagram. i could understand. thank q sir jitendra
OK, Here is a picture:
As you can see the Reset switch is connected to pins 5 & 7 and the Power switch is connected to pins 6 & 8.
This is directly from the manual. You can download it from:
http://www.mercury-pc.com/downloads_list.php?productid=684
The link is at the bottom of the page.
Thanks for using Fixya. A "Fixya" rating would be appreciated.
Jan 22, 2009 | Mercury KVM400M-U Motherboard
Usb Port is not working
Mercury Chipset Mother Board Number : pig31Z
Problem is USB Port is not working... so send me the driver detils throw out my mail....thank you
prajen2008@gmail
May 16, 2008 | ASUS P5GD1-VM Motherboard
My mercury motherboard cd was lost
HI,,,,,,,,
i have problems with my mainboard.
for i need mercury mainboards instllation cd
i had tried on kobian.com but thre is no current downloads
plz guide me for solution
Mar 22, 2008 | Mercury KVM800M Motherboard
Mercury MOTHERBOARD KOB P4M266 NDFSMX
I AM NOT HAVING MOTHER BOARD CD TO INSTALL HIS DREVERS AND HOW TO DOWNLOAD HIS DRVIERS BY INTERNET
Mar 04, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Mother board driver
hi
i need kvm266pm-u motherboard, vga, sound driver
Feb 10, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Computers & Internet Logo
78 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
