Question about ACCO Brands Kensington Thin and Light 70w Ac/Dc Power Adapter (38009)
Need a 7.4mm with pin coluor coded power tip for kensington 70w ac power supply model 33192
3 Suggested Answers
ErusTownsend
  • 592 Answers
SOURCE: Which Kensington notebook power supply tip will
this is not a supported laptop for kensington power adapters. here is a list of compativle brands and their tip numbers
http://us.kensington.com/html/13675.html
Posted on Feb 12, 2010
EngineerMC
  • 185 Answers
SOURCE: Replacement tips for Kensington 120W AC/DC adapter model 33197
I have the same model adapter for my dell, I believe there is a number on the tip that you need, have you tried ebay for the part they are called 'smart tips'. I think it's a different adapter direct from kensington now, but you can buy them from 3rd parties.
http://us.kensington.com/html/10442.html
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270522811796
Posted on Feb 14, 2010
Will Universal AC Adapter 15V 16V 18V 18 5V 19V 19 5V 20V 22V 24V 70W work for BMS 10H product
I suggest that you use the ac adapter intended for the model of your computer to avoid from getting any problems.
David
May 26, 2013 | Computers & Internet
My Gateway laptop use AC cord with the output 19v = 3.42A. can I use the AC cord with the output 19v = 3.95A?
Yes you can use one that has an higher current rating. The system will only use what it needs. If you try to use one with an lower current rating the power supply would fail. Just check to make sure the pin out is the same..ie postive tip or negtive tip.
Feb 23, 2010 | Gateway HQRP Replacement Laptop AC Adapter...
Which Kensington notebook power supply tip will fit a MSI CR600 notebook computer
Feb 12, 2010 | ACCO Brands Kensington Wall Notebook Power...
Feb 12, 2010 | ACCO Brands Kensington Thin and Light 70w...
My dvd burner won't burn - format only +. It's a _NEC DVD_RWND-3520AW I had this problem before and I was given the link of some firmware but I have updated now again (as I reformatted computer since the...
Ru using any softwares to burn DVD disk.( like nero )... if the operating is XP you need some software to burn the DVD disk,,,,where as VISTA OS has DVD native burning ,, where u can burn DVD with out any third party software. think this helps u.......TC bye.
May 14, 2009 | Falcon 4620 Accessories: POWER...
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Need to know power requirements for the kensington k33141 usb hub
hello,
i believe i know the answer. i have the kensington pocket hub se 2.0 model: k33141. it seemed to work with the adapter i found in our closet. it is a dve Model : dsa-0131f-05 us 13 and it outputs 5v 2.5a. the adapter has a thin profiile like it would be plugged into a strip. and it has an rf blocker which suggests computer equipment.
Apr 05, 2009 | Kensington (1500100) Networking Hub
Flashing red light on the Kensington wireless mouse base
I still have the manual for my mouse.  Model number 64321.
When this mouse was manufactured it used NiCad batteries which developed a memory much more than the newer batteries.  The older NiCad batteries needed to be conditioned occasionally so Kensington provided a way to do that with the charging base.
The red light is for indicating discharge status of NiCad batteries.
The red light will flash quickly when you press the battery discharge button on the bottom of the base.  This indicates that you now have 5 seconds to place the mouse in the charging base for battery discharge.
The red light will flash flash more slowly when the battery is being discharged.
After the battery is fully discharged, the base will then charge the batteries.
It should be noted that very few manufacturers of products that utilized NiCad batteries provided a "battery conditioning" feature.  Kensington was unique in this regard.  Battery conditioning allowed NiCad batteries to have a longer useful life.
Now maybe you can help me....  I lost my power supply that plugs into the USB connector.  If you have yours, can you tell me what the output voltage is and what the polarity is of the inner pin.  This will be marked right on the power supply base.
I plan to just get a generic power supply from Radio Shack, but I need the voltage value and polarity.  Until then, I can still use the mouse, but it won't charge.  FOr now, I'm just using standard AAA batteries.
Thanks.
bartman9@earthlink.net
Mar 17, 2009 | Kensington StudioMouse Wireless
TIP MELTED
I know it's kinda lame, but you might be able to get something from Radio Shack. Something else to try is to look at a universal power supply. Some have interchangeable connectors and one might work. By the way, I saw in a store this weekend there are "generic" laptop power supplies that come with several different tips as well.
Nov 30, 2008 | Dell Dimension 3000 PC Desktop
ACCO Brands Kensington Thin and Light 70w Ac/Dc Power Adapter (38009) Logo
Top ACCO Brands Car Audio & Video Experts
xxxxxx xxx
Are you an ACCO Brands Car Audio and Video Expert? Answer questions, earn points and help others
