Question about Cameras
PowerShot S95 Error E32 - Cameras
5 Suggested Answers
  • 173 Answers
SOURCE: How do I solve error
The following is an answer taken from site: http://answers.yahoo.com/question/index?qid=20101220203847AAmODI4
"You can try a hard restart:
- put fresh batteries in the camera but no memory card;
- double click the on/off button so the camera turns on, then off;
- hit the button again and, hopefully, it will start normally.
If this doesn't help, call Canon tech support. E-series error codes may indicate hardware or firmware issues that need professional repair. In the U.S. the Canon customer support phone number is: 1-800-OK-CANON."
Hope this will help. Best of luck.
Posted on Jan 08, 2011
  • 6 Answers
SOURCE: canon powershot sd1400 is e32 error?
The problem is related to the mechanics in the optical image stabilization. There are 2 plastic ball bearings inside the shutter/lens module that can pop out of their round holders that are held in by 2 springs. This can occur by simply dropping the camera with the lens extended. I fixed many of these particular models and would not recommend an amateur attempt the fix as the complete lens has to be disassembled. A very poor Canon lens design.
Posted on Oct 08, 2011
  • 64 Answers
SOURCE: Canon Camera Error E32. Camera
The most common problems in these small tiny cameras is the lens alignment. If you drop the camera with the lens extended this alignment will ****. If you are a handyman you can fix it by yourself by oppening it inside and realign/putting the lens in right position. Sometimes you can do that by forcing them to extednd manualy but that is very risky. If not handyman I recomand you to take it to a repair shop.
Posted on Jan 27, 2011
ZJLimited
  • 17970 Answers
SOURCE: how can i solve my canon PowerShot SD1300 IS E32
Error E32 is mostly a lens error and it denotes that your lens barrel has some problem.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair.
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
Now there isn't much to do here. I am listing a few techniques that might help, but do it at your own risk as it can help in some cases or make it worse in others.
1. Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
2. Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
Hope this helps to solve it.
Posted on Oct 02, 2011
E32 error in canon A3100 is
hi i have roblem in my camara A1300 IS , restart E32 what i do?
Mar 26, 2012 | Canon PowerShot A3100 IS Digital Camera
Error e32 sx210
Getting Canon error codes usually means a trip to the Canon service center for a fix. There's a discussion in the DPreview forum regarding the same problem.
Apparently an E32 error code results in the camera powering off in exactly 60 seconds in the playback mode. It not necessarily affects just the G11 but other PowerShot models too.
Generally E-series error codes mean either a hardware or firmware issue that cannot be rectified by the end user.
Hope this helps
Positive feedback ALWAYS welcome :)
Mar 03, 2011 | Canon Cameras
Cameras Logo
666 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
