Question about Westinghouse Refrigerators
I have a two door BJ505T-R, freezers working well, fridge is not cold now matter where I set the termostat
rylee_smith
  • 8619 Answers
SOURCE: freezer working fine but fridge wont go cold!
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Posted on Mar 25, 2009
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
I HAVE SIDE BY SIDE FRIDGE/ FREEZER THE FRIDGE IS WORKING AND THE FREEZER IS ONLY AS COLD AS THE FRIDGE IT DOESN'T FREEZE THE FOOD. I HAVE IT IN THE GARAGE NEAR THE DOOR SO IT IT VERY COLD , I LIVE IN...
I'm in Mass and also buried in several feet of snow, so I have an idea how cold it is in your garage. As a matter of fact, you don't run a compressor in cold outdoor weather, which is basically what you're doing. AC units that were meant to run outdoors have a compressor heater, your fridge doesn't have one.
Feb 18, 2015 | Refrigerators
Mini fridge not getting cold,freezer only gets cold?
If it's less then a year old you have a warranty, if it's older you are better off replacing the unit as direct parts are not available and subs would cost more that the unit.
Mar 24, 2013 | Haier Refrigerators
Inside my fridge there is a round manual termostat that is numbered 1...to 7 i like my fridge cold so what 1 would i have 2 have it on ..also up over the top of the door there is a button wit a pic of a...
firstly the button that turns orange is the freezer "fast freeze"control,you use this when you have defrosted it or move it to another house,the control in the fridge should be set so that the interior is at +2c to +5c,1 is the warmest 7 is the coldest,if you havnt got a fridge thermometer,do the lettuce test,if the leaves go black/soggy,its too cold.
Dec 22, 2010 | Whirlpool GB9SHKXL Bottom Freezer...
GE Monogram Built In Fridge-freezer is not cold enough, but ice is ok...refrigerator is too cold no matter the setting. Someone suggested vacuuming filter above the fridge. Would this work?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Feb 23, 2010 | Refrigerators
Refrigerator not cold/ freezer is
Sep 24, 2009 | Refrigerators
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
Aug 22, 2009 | Refrigerators
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Kg34na90gb fridge freezer - fridge temperature cold, no matter what the setting on door control. Fresh food suffers as a result of almost freezing conditions.
turn the freezer up to highest setting and set the refrigerator control to about half way. this will block some of the airflow into the refrigerator.
Jul 06, 2008 | Siemens Refrigerators
Refrigerators Logo
173 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
