Question about Weber Q Grill
Q 220 Burner tube is not initially igniting all the way around and then some ports are going out. New gas tank so plenty of gas
  • 4 Answers
The ports are probably blocked with grease. This happened to me - I removed the burner tube and used a steel bristle brush to clean the holes - the clue is to use the brush from front to back/back to front, not from side to side - side to side just moves the grease from one hole to the next. Worked like a charm, thought I would have to buy new burners.
Posted on Jun 04, 2011
Grill will not start...looks like gas is not getting to the burner. how do you fix it?
Hello, here is my check list for your most common gas grill lighting problems:
1) Check your tank. Is it empty or nearly empty? The tare weight (T.W.) of your cylinder is stamped on the collar. This is the weight of your empty cylinder, usually around 18 lbs. Weigh it on your bathroom scale2_bing.gif. Propane weighs 4.25 lbs/gal. If it weighs around 20 lbs or less - Refill it. If not, go to #2.
2) Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve and let sit for a few minutes. Or just disconnect it and reconnect it. Turn the tank valve very slowly and then try lighting it again. If it doesn't help, go to #3.
3) Is the igniter sparking? Some are battery powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
4) You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
5) If none of these resolve the issues you are having, it is also possible you have a faulty or defective regulator, which may mean replacement. If the pressure still seems too low and none of the above has helped, and you have a silver/gray regulator; many have an adjustment screw on the top center of the diaphragm. Remove the outer cap and turn the inside screw clockwise in 1/4 turns to increase the pressure until the desired flame size is accomplished. Flames should be as blue as possible, but will burn orange if there is food or drippings on it. Yellow flames are not good, and will soot up everything and not cook as hot as blue flames do. Yellow flames could mean you do not have the right air shutter adjustment, clogged burners, or possibly defective burners, as mentioned above in #4.
6) Also make sure you have the hose connection tightened snugly to the propane tank valve to ensure the inner valve seat is fully depressed allowing gas to exit fully without any restriction. The black plastic female fitting should be hand tightened only. Older versions that use a left-hand male brass POL valve, requires a 7/8 open end wrench or adjustable wrench to tighten.
Jun 27, 2010 | Weber Genesis Silver B Grill
I have a charbroil commercial gas grill that won't ignite. I have a full tank of propane.....
2) Make sure you didn't turn the gas tank valve on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve, disconnect it and reconnect it. Turn the tank valve back on very slowly and then try lighting it again. Make sure all your grill gas knobs are turned to off when you turn on the tank valve and that you only light 1 burner at a time. If it doesn't help, go to #3.
3) Is the igniter sparking? Some are battery2_bing.gif powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style2_bing.gif igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
Hope this helps! Good luck in your trouble shooting! Douglas
Jun 08, 2010 | Char-Broil CharBroil Master Flame Gas...
I have a Thermos 461262407 Propane Grill. It will not light, gets good ignition, and I just got a filled propane tank. I don't hear the sound of gas entering the tubes when I turn on the knob. Is it...
Hello, here is a check list for your most common gas grill lighting problems: Hopefully one will solve it for you.
May 30, 2010 | Thermos Stainless Steel Gas Grill
The grill will not light.
Hello, here is a check list for your most common gas grill lighting problems. Maybe one will help.
May 28, 2010 | Coleman LG40811E Grill
Have a large mobile propane grill with burner problems
Ok, here is a check list for your most common gas grill lighting problems:
May 19, 2010 | Big Green Egg Extra Large - XLHD...
Burners will not ignite and it seems they are not getting any gas
Here, try my trouble shooting checklist and see if one of them works for the most common gas grill lighting problems:
May 17, 2010 | Brinkmann 810-2300-B Grill
My grill will not ignite. I tried both ways. What could be wrong?i hear the gas but it wont start
Ok, here is a check list for you of the most common lighting problems:
1) Check your tank. Is it empty or nearly empty? The tare weight (T.W.) of your cylinder is stamped on the collar. That is the weight of your empty cylinder, usually around 18 lbs. Weigh it on your bathroom scale. Propane weighs 4.25 lbs/gal. If it weighs around 20 lbs or less - Refill it. If not, go to #2.
2) Make sure you didn't turn the gas on too fast. Some gas hoses have a built-in excess flow valve that stops the flow of gas to a trickle if opened too fast. Close the tank valve and let sit for a minute. Turn the tank valve slowly and then try lighting it again. If it doesn't, go to #3.
3) Is the igniter sparking? Some are battery powered-check the battery or replace it. If you have a standard push button piezzo igniter or a rotary style igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. If not, go to #4.
4) You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the holes are not allowing much gas thru anymore. It's also possible the burner has rusted so bad, it has too large of holes, falling apart or cracks along the seams. If so, replace burners immediately. It is unsafe to use. Your local propane co can usually order what you need and some will even do the work, if you are uncomfortable doing it.
May 12, 2010 | Weber Genesis Silver A Grill
Burners won't fully heat
Check your venturi tubes(the ones that feed the burners) for spider webs.
Eric
Oct 12, 2009 | Weber Genesis E-310 Gas Grill
Gas burners will not ignite ater cleaning stove top
hi friend,
On stove top burners that have sparklers that are not visible at the burner head, the burner heads have ignition ports. If the sparklers are functioning and the burners won't lite, chances are the ignition ports are clogged or restricted.
Ignition ports are tiny holes up one side of the burner head. If these holes are restricted, they must be cleared out. Cleaning can be accomplished using one of three methods.
Most commonly, a large sewing straight pin needle can be used. DO NOT enlarge the ignition holes. Doing so will have adverse burner lighting effects.
Burner heads where the flames will not burn completely around the entire circumference of the burner head, the holes which do not have flames are clogged up and need cleaning.
In cases of extremely dirty burner heads, soaking the burners in very hot water with plenty of dissolved automatic dishwasher detergent for several hours, rinsing and drying or a combination of both methods for heavily soiled burners.
hope this helps u
thank u for using fixya
please rate me..................
regards
sivaranjini
Sep 12, 2009 | GE Kitchen Ranges
Weber Q Grill Logo
1,059 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
