Question about Samsung ES60 Digital Camera
My samsung ES60 is not charging..the charger's indicator light is color red for almost almost 3 hours and still my camera won't open..when i check the camera..it's not getting hot..and the camera"s indicator light doesn't have a light..
5 Suggested Answers
zohail
  • 1223 Answers
SOURCE: light on my samsung digtal camera charger is flashing orange and
pls checck the batt it is not taking the charge they are weaken and old pls ccheck it
pls rate me fixya for this if u like
Posted on Mar 09, 2009
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
Posted on Jul 02, 2009
prerit_777
  • 214 Answers
SOURCE: I cannot charge my Samsung L210 digital camera
it has a technical problem you should go to a person who repairs
Posted on Aug 23, 2009
  • 906 Answers
SOURCE: samsung ES60 not charging the
Link
Kindly consult this problem to your nearest Samsung Authorized Dealer as the possible problem is with the charger as it does not charge anymore. You can browse above link for Samsung Support Team.
Thank you.
Posted on Aug 02, 2010
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
I have a Samsung PL100 digital camera. I dropped it while at beach, it was switched off. When I went to switch it on the lens came out but then it made a buzzing sound and switched itself off. The lens is...
I had the same exact issue.... try putting it on the charger, even if you think it's fully charged... If the light is red, leave it on the charger until it turns green, and then remove the battery for a second and then put it back in the camera before turning it back on..... try turning it on. If it still won't close, put it back on the charger. If the charger is automatically indicating a red light, that means you have exhausted your battery and will nee a new one... they cost about 5-11 dollars on amazon...... hope that helps...
Jul 20, 2012 | Cameras
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
I have 2 batteries but some how i can not charge even i have left them 24 hrs to charge
Digital camera batteries are usually with an external battery charger.
The charger maybe faulty, the charge adapter will have a LED indicator to indicate that it is charging.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 15, 2012 | Samsung Digimax L730 Digital Camera
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Samsung ES60 not charging the charger just keeps blinking a yellow light and it does not charge at all
Link
Thank you.
Aug 02, 2010 | Samsung NV24 HD Digital Camera
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Samsung ES60 Digital Camera Logo
122 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
