My vga card is not working. - Computers & Internet
  • 83 Answers
Hello! kindly check if its installed if its not, u need the accurate driver of ur VGA, if its done, if its not working try to replace it...
Posted on May 29, 2011
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they want...
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers.
I hope that you find this useful.
Mar 26, 2015 | Lenovo ThinkCentre Computers & Internet
What cable do I use to get a G0773 Graphics card (Dual VGA/Single Port) to work with a single Acer P215H Monitor?
check vga cable or VGa card for enhance of video for more tips sign in ghulam rabani
Oct 23, 2012 | Dell G0773 Video Card
No video signal from Asrock Extreme 7 Gen 3 motherboard from VGA or ADMI
As i can see your motherboard does not have an internal VGA card.
Is your monitor working ?Try another monitor.If problem still exists, remove your VGA card and place it again fimly to a PCIex slot. (see manual).If problem still exists try another PCIex slot.If problem still exists get a working PCIex VGA card and replace yours.
Jan 04, 2012 | Computers & Internet
No vga
Make sure you have connected the VGA cable to the right VGA socket. If you have one on the motherboard and have a separate one on the graphics card, the graphics card usually takes priority over the motherboard one. If its not the case, remove the graphics card and then check in the BIOS to make sure the graphics card has priority an connect the VGA cable to it.
Obviously if the graphics card lacks VGA connectors and only offers DVI or HDMI connectors you will need an adapter to make the VGA work on the card.
Jul 23, 2011 | Mercury PVCLE266 Motherboard
Trying to set up a dual monitor with onboard VGA and with Sapphire radeon x300 video card. The Radeon is taking over and not letting the motherboard vga work.
sir the mother board accept only one VGA card if you installed a new one the the other on will disabled if f you wanna run multi screen at the time just but the multi VGA dongle hub it is affordable and works fine dont need any driver buy it it`s useful affordable and have fun
May 23, 2011 | ATI Sapphire RADEON X300 SE 128MB DDR...
PNY 7130 630i VGA port doesn't work
if it has a vga connector on the motherboard, it does not need a secondary video card.  If the vga doesn't work and you have no display at all, not even on boot up, then you have a bad motherboard.
Mar 07, 2009 | PNY Technologies GeForce 6200 128MB AGP...
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Monitor not working
sorry friend i ws lill busy so could not rply.
Anyways
  • This is the VGA out: ebc4b94.jpg
  • And this is the connection for VGA comes from monitor: c99e5d1.jpg
  • Now if your VGA - Out is mounted on your motherboard then you have on-board VGA card.
  • means you have PCI VGA card.
Now if you want to use another PCI card just remove the one which you are using and use another one. Use only one PCI card for VGA, need not to use more than PCI VGA card at a time.
Thanks
Iqbal
May 13, 2008 | Computers & Internet
TFT screen not working
hi
clean your vga ,fix it in your agp slot also remove dust from it .
reconnect all cable to board.also clen processor case.
clear your bios.
take away cmos cell for 15 minutes.
Mar 24, 2008 | MSI FX5200-T128 (128 MB) Graphic Card
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
