Question about Singer 2932 Mechanical Sewing Machine
I just bought a Singer 2932. Everything is threaded correctly and put into place correctly (I triple checked the manual). However, when I move the needle downwards, it jams in the down position and won't go forwards more. It does go backwards perfectly, but I cannot sew anything. I eyeballed the inside where the needle interacts with the bobbin, and well... nothing seems to be amiss? I'm not sure, since I've never had a sewing machine this complex before. Nothing in the manual seems to help. Any suggestions?
SOURCE: Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Posted on May 01, 2009
  • 323 Answers
SOURCE: singer 2932 automatic threader
A new part is faster and easier but sometimes the problem is a bent hook( the tiny part which goes through the eye of the needle). Remove the needle to see the part better and pull the threader down. Look in the very center of the threader for the hook. It is probably pushed to the right.Using a small screwdriver or other thin piece of metal, force the hook back to the center. Try it and continue until it enters the eye again. By the way, a Singer dealer can get this part for you for under $10.
sewman7
Posted on Aug 11, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
ddebita
  • 5 Answers
SOURCE: I have a singer model
I've been sewing since I was six (with mom's help), but all sewing machines are basically the same. The feed dog, which is what advances the fabric is most likely not moving. If you look at the area just under the presser foot & needle you'll see little "teeth". This is the feed dog. Take the thread out of the needle and run the machine without any fabric. Watch those teeth. They should rise & lower into the base. If they don't move when the foot pedal is pressed, then that is your problem and you'll need to take it to a repair shop. Good luck.
Posted on Nov 06, 2010
How to wind bobbin on model 4411
Do you mean the Singer 4411 Heavy Duty sewing machine? If so,
first place the spool on the spool pin with an appropriate sized spool holder, if you are starting the project. Snap the thread into the thread guide to the left of the of the spool pin. Wrap the thread clockwise around the bobbin winder tension discs (slightly to the left and forward of the thread guide). Bring thread towards the bobbin spindle. Thread the bobbin (put the thread through the hole in the bobbin). Place the bobbin on the spindle with the hole up. Move the bobbin spindle to the right. Hold onto the thread above the bobbin and step on the foot control pedal. When the bobbin finishes winding the thread, cut the thread at the top of the bobbin and the incoming thread from the spool. Move the bobbin spindle to the left and remove the bobbin. If you have already threaded the machine for sewing, you will need to remove it from the various guides and tension discs that are used in sewing. Then after winding the bobbin, re-thread the top thread.
The directions to wind the bobbin are in the manual on page 12 (page 19 of the PDF). You can find many Singer manuals at the Singer support page: https://www.singer.com/support . The 4411 support page is https://www.singer.com/search/support?lp=support&title=4411 . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf .
I hope this helps.
Apr 30, 2018 | Sewing Machines
SINGER MODEL 2932 HOW TO MAKE BUTTON HOLE
try this link for a free manual and it should have the information
in it that you need
http://www.singerco.com/uploads/download/463_2932_esf.pdf
Jan 28, 2013 | Singer 2932 Mechanical Sewing Machine
I need to know the steps in making a button hole with the Singer sewing machine; model 2932>
They have a free instruction manual download on singer website
On the homepage at the bottom look for instruction manual & click on it
It will take you to a page where there's a box put in the model number 2932
Then click search
The second one is a free download
Aug 25, 2011 | Singer 2932 Mechanical Sewing Machine
How do I tighten the tension. My bottom thread is
To increase the tension,turn the dial one number up until the thread length/tension is correct for your needs. You may download the manual free and info on adjustments is on page 28. Happy Sewing!       http://www.sewingmachinesplus.com/media/products/singer/2932/Manual_2932.pdf
              # 0             0
Jul 24, 2011 | Singer 2932 Mechanical Sewing Machine
My machine motor will run but the needle won't move up and down unless I manually move it. I can hear the motor running but nothing is moving on the machine. I've tried checking everything and am out of...
Its sound like the belt is slipping, maybe if its under warranty try to call the place that sold it to you. Most motor belts are accessable for adjustment and servicing. Its on the right side under the handwheel.
Jan 15, 2011 | Singer Sewing Machines
I have a singer model #2932 It will not advance the fabric, just keeps sewing in the same place
Nov 06, 2010 | Singer Sewing Machines
The thread is not locked and no stitch formation
I know you do not want to hear it but your threading is not correct. Do this test, put the presser foot up, pull on the top thread it should pull smoothly,now put the presser foot down, pull the thread again and it should barely move. You have to make sure that the thread is getting the correct tension in the threading path and not tangled. Now check your bobbin threading, is the thread pulling smoothly? If, not see the way your bobbin is unwinding, do you have it in backwards? By the way, how is your needle, when is the last time you changed it? Do so now and make sure that it right size for your material and inserted right, flat side face the rear. Have you done any maintenance? Like oiling, cleaning out lint and such? Refer to your manual for oiling points. If, you do not have a manual go to www.singerco.com and download a free one and enlarge the diagrams to see everything really clear and save a copy. Singer have excellent customer service, and can be reached at 1-800-4singer.
Oct 24, 2010 | Singer 8280 Mechanical Sewing Machine
I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Aug 20, 2009 | Sewing Machines
Free download of singer overlocker manual
Jag har en industri overlock singer 81k73 Jag kan inte trä den
Har du några förslag
Mar 25, 2009 | Yamata FY14U4AD
Singer 2932 Mechanical Sewing Machine Logo
61 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
