Question about Acer Aspire L100 PC Desktop
ACER L100 OVERHEAT
Like to see your auxillary fan plans. Was trying to figure a way to do that too! A thousand thanks in advance(ATTIA)!
  • 49 Answers
I just fixed one of these, it has nothing to do with hardware, it s a sftware problem. i posted what i found on the other acerL100 quetons
Posted on Sep 29, 2008
Yes send the case mod and I will tell you how I may have already solved it?
Posted on Sep 26, 2008
    Problem Solver:
  • 9 Answers
Are you comfortable with a little case mod. Just did this myself & solved overheating issue. If interested let me know & I will provide step by step instructions.
Posted on Sep 25, 2008
My engine overheat when A/C is running on a slow moving traffic or on parking.
I would check and see how much air is actually moving thru the radiator. The fan may not be running fast enough or you may have debris blocking the air flow. Also make sure the system is full of coolant and no air pockets.
Nov 03, 2015 | 1995 Jeep Grand Cherokee
I am running Wxp on my Acer L100. After about 15
first things first pls check if the cpu fan is seated properly.
if not pls try to reseat the cpu fan, but before doing it put thermal paste on top of the cpu to haver a better contact on the cpu
if the fan is seated properly check the rpm of the fan on bios mode see if the rpm of the fan is fast enough.. if not then there's the problem.
this things only happens if the cooling system of your processor is malfunctioning. Your built in hardware monitor tends to turn of the computer to prevent further damage,,
Jan 11, 2010 | Acer Aspire L100 PC Desktop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Acer Aspire L100 heat problem
go into the BIOS and disable the smart fan. The next boot will allow the fan to run at full speed, approx 7200rpm instead of 2800 rpm and the machine will not overheat. However, its will sound like an aircraft on takeoff!
Oct 20, 2008 | Acer Aspire L100 PC Desktop
Possible overheating problem for Acer Aspire mini L100
I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
Sep 26, 2008 | Acer Aspire L100 PC Desktop
Acer L100
Its a nosiy solution but in the BIOS, switch off the smart fan. The fan will speed up from 2800rpm to aroun 7200rpm and the tower will not overheat.
Aug 04, 2008 | Acer Aspire L100 PC Desktop
Another owner of the acer L100
For L100 drivers, go to the acer website and download them. There is also a link to order a disk to reload the OS.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7293&areaid=7&website=AcerPanAm.com/us
Over Heating Problem In Acer Aspire L100
There are two solutions to this problem. First set the fan in the PC Bios to rub at full speed all the time. This was too noisy for me.
Second, If you are running Windows Vista, you can adjust the Maximum Porcessor Utilization. From the Windows Control Panel select the Power Options icon. Then select "Change plan settings" for which ever power plan the PC is set to use. Then select "Change advanced power settings". Expand the "Processor power managment" by clicking on the "+" symbol. Finally click on the "+" for "Maximum processor state". I would try changing this setting to "90 %". This worked fine on my ACER L100 and it no longer overheats.
Jun 08, 2008 | AcerPower F1 PC Desktop
Acer Aspire Mini PC
Hi, you will be able to purchase a mini ATX format board by almost any manufacturer that will fit the acer case, the only problem you may hve is the PCI and Graphics cards will need to be low profile standards but these are also available if you are not planning on gaming then the on board graphics on most new boards will do all you ask of them.
Regards mistyman
Oct 14, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire L100 PC Desktop Logo
194 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
