I have an LG inverter split system room air conditioner model lsz122vm-5. However I do not have the manual and I cannot change it from cool to heat. Any assistance would be greatly appreciated.
bobotfel
  • 236 Answers
SOURCE: air conditioner remote
here are some icon meaning, this may help.
Posted on Apr 28, 2008
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
Sparky2012
  • 102 Answers
SOURCE: I have a TCL 2.5hp split system air conditioner
I will star checking freon pressure but you going to call an HVAC company to do that. Please turn it off or you will damage the compressor, if is not already.
Posted on Dec 06, 2009
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
Solution of code Error Ch-10 in LG AC
LG canceled inverter AC ch10 error
Jun 03, 2013 | Heating & Cooling
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
LG split inverter model LSL122V3 and it doesn't cool and shuts down after a few minutes with the green led flashing five times repeating.
Communcation error between in and out.
Dec 31, 2010 | LG LSC121PMA Split System Air Conditioner
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
I havent got a manual for my air con and i want to know how to get one or how to change from heating to cooling
See what you can
find here by typing the following into the search bar:
LG LSC121PMA Split System Air Conditioner?
Nov 02, 2009 | LG LSC121PMA Split System Air Conditioner
Air conditioner remote
Apr 27, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
