Question about Toshiba Tecra A8-S8514 Notebook
How to open the cmos setup - Toshiba Tecra A8-S8514 Notebook
Hp EliteBook discontinued from workplace, need bios administrator master password. Model 6930p s/n: 2CE910FDBF SERVICE TAG: E6930pUP8400W4X12MINNNN20QeS
hi!
this is how to bypass CMOS SETUP password
*open the cover of you laptop,
*remove the cmos 3v baterry.
*remove the main battery
*push the power button for 10 sec.
*wait for 5 to 15 minutes
*put back the cmos battery and connect the main battery
turn on your computer and enter to cmos setup
Jul 08, 2011 | HP Computers & Internet
Need hard drive password
You need to go to CMOS setup or BIOS setup. Follow these steps: 1. After pressing the power button of your Laptop, press F2 key until it display the CMOS setup menu. 2. Select the Security tab then it will open the System and HDD security. 3 Enter your security password on it. 4. Save your settings. Then exit.
Apr 20, 2011 | Dell Latitude D505 Notebook
What's the password
Oct 12, 2009 | CTL IL1 Notebook
When I turn my computer on, I get an istant error message: CMOS setttings error. Any idea what to do?
I THINK YOUR MOTHERBOARD BATTERY MAY BE DAMAGED OR DOWN. YOU HAVE TO REPALCE THE BATTERY AND TRY AGAIN TO START THE PC.
Oct 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
How to resert a cmos password
First of all as you have forgotten the password to reset the password you have to open the notebook and remove the CMOS Battery for a while and then replace it restart the notebook after you restart the notebook all the default setting will be loaded in the cmos setup you can enter the cmos setup and set the password again.
Jun 04, 2009 | Acer TravelMate 2300 Notebook
My hard disk would not open
is the hard disk detectable in the cmos setup? to know how to enter the cmos setup look for the press "DEL / F2 / F10 to enter setup when you power up the pc. check for the boot option under cmos and check the hdd if cmos can detect it. otherwise hard drive has a problem. if hard drive is detectable, try reinstalling windows xp. other means is to check boot sequence by pressing F11 during start up. this will display the option on which you would like to boot from.
Feb 19, 2009 | Microsoft Windows XP Professional for PC
Resetting CMOS due to virus
You will be able to reset the cmos settings if you can enter the cmos setup during startup.
Nov 24, 2008 | Computers & Internet
OPEN PASSWORD BIOS
How to enter the BIOS or CMOS setup. Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
Press <F2> to enter BIOS setup
Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
Should get ya back on line , Good Luck
Dec 01, 2007 | Fujitsu LifeBook C4135 Notebook
Toshiba Tecra A8-S8514 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
