Question about Samsung ML 1210 Laser Printer
Hi All, I have ML-1210 which has parallel cable connected But in my cpu i do not have parallel port except USB port I am using Win 7 Please help in how the connection works and to download which drivers
  • 1,219 Answers
to solve your problem you need the USB to Parallel adapter. Find examples here:
http://www.google.hr/#hl=hr&source=hp&q=usb+to+parallel+adapter&oq=usb+to+para&aq=1&aqi=g10&aql=&gs_sm=e&gs_upl=1146l3721l0l11l10l0l3l3l0l240l1191l0.4.3&fp=92b2044ee890eadb&biw=1366&bih=611
Regarding drivers, if you dont find for Win 7 try from XP.
Hope that helps!
Posted on May 29, 2011
Can I use the scanner with Win 7?
You can only use usb to scsi adapter check this link for some models:
USB to SCSI
Dec 10, 2013 | Epson GT 12000 Flatbed Scanner
I have an old serial printer that works fine, I can not connect it to my new computer via a parallel to usb cable convertor on windows 7!
Hi craig931, First try downloading the latest driver of your printer and your usb converter compatible for windows 7. Second Checked your device manager if your printer and usb to parallel driver properly installed, it should be there. If not yet installed try using different usb port one at a time until the cable have been detected. Third if you see already the printer port force to change it to USB001 or Com1, then try to print. regards,
Sep 26, 2011 | Office Equipment & Supplies
Am looking at buying a friends 320 scanner, He cant find the booklet or cd 4 it. also doesn't have the parallel cable eather. Can i get this from the company? Also I havw windows xp. will this work on...
First you would need to make sure you have a parallel port on your computer, because if you don't, you would need to get an adapter of some sort for either a p2p or usb port, whichever you prefer. I'm not sure if you can get a parallel cable from the manufacture, but you could probably find it on eBay. With an older scanner and a newer computer, you can probably just plug it in and it will work, but if you need the software, go here: http://www.nodevice.com/driver/320P/get25293.html
Hope this helps!
Aug 25, 2011 | AcerScan 320P Flatbed Scanner
PSC 1210 ALL IN ONE WILL NOT CONNECT TO MY NEW DELL INSPIRON WITH WINDOWS 7 . IT SAYS THEREIS A COMPATABILITY ISSUE?
drivers are no available on website for win 7. wat you can do you can directly connect ur pritner to computer with usb cable you will se message found new hardware. installing device drivers. after some time it will show you message device is ready to use. then click on start. go to start search adn type pritners. then hit enter. it will open pritners windows.
in that window click on add a pritner on top. then select add a local pritner. then it will says select existing port select usb vertual pritner port and hit next. then under manufacturer select hewlett adn packard and under prtiner select psc 1200 series prtiner and hit next. do not share this pritner follow onscreen instruction to finish add a pritner wizard.
Dec 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Lexmark X4550 not printing in Vista can't enable bi-directional
"Bi Directional Printing" is a statement of Parallel Port printing. Are you connected from your PC to the Printer via the parallel port?\
Did you disconnect the USB cable form the PC and then delete the current driver prior to installing the Win 7 driver?
Nov 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
Lexmark E210 on x64
Lexmark never updated the E210 driver for Windows Vista / Windows 7. Luckily, the printer is identical to the Samsung ML-1210 printer, which has better drivers that are Vista / Win 7 compatible. (The new drivers also work if the printer is connected to an XP machine, but is being shared with a Vista machine on your network.)
Go to the Samsung Support website (www.samsung.com/us/support/) and then type ML-1210 in the search box in the middle of the page. Click on the ML-1210 result, then click the "Downloads" tab, then below that, click "Drivers." Scroll down to get the correct driver for your system.
Uninstall any old drivers before installing the new drivers.
John Dollison
May 27, 2009 | Lexmark E210 Laser Printer
HP2100 PRINTER NEEDS USB PORT ON WIN XP LAPTOP.
You have to purchase a Parallel to USB printer cable.
Jan 03, 2009 | HP LaserJet 2100 Printer
Can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Sep 29, 2007 | Samsung ML 1210 Laser Printer
Unable to print
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Aug 30, 2007 | Samsung ML 1210 Laser Printer
Samsung ML 1210 Laser Printer Logo
128 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
