We have a gem cool air conditioning unit in our office but no manual. It doesnt seem to be cooling at all (it was installed last week and it was working fine then) and we are not sure what settings we are getting wrong. Is there somewhere online where we can find the manuals for this brand?
Master_Tech
  • 770 Answers
SOURCE: My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Posted on Jun 09, 2008
refritech08
  • 149 Answers
SOURCE: air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Posted on Jun 15, 2008
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
  • 18 Answers
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Posted on Dec 11, 2008
t1m130
  • 86 Answers
SOURCE: RUNS BUT DOES NOT COOL TOO WELL.
if the compressor runs for a short time only it could be overheating due to a lack of refrigerant i would suggest finding a contractor who specializes in hampton bay to take a look at it
Posted on Jul 29, 2009
Blows very cold air during dehumidify mode.
se this fact: God bless you
air conditioning system cools but does not dehumidify the room. The most common cause of inadequate dehumidification by an air conditioning system is the installation of a cooling unit which has too much capacity, or is "over-sized" for the space it is being used to cool. What happens is simple:
If an air conditioning compressor unit is oversized (too many BTUH of cooling capacity) what happens is it cools the room so quickly that the system does not move enough total volume of air across the cooling coil to remove much moisture before the room temperature has dropped to the A/C cut-off point.
In other words, an air conditioner needs to run longer, and move more total volume of air through itself to drop room humidity than it does to just cool the air. So "bigger" cooling capacity or higher BTU capacity for an air conditioning system is not necessarily better, and it can actually be a problem.
Sep 30, 2012 | Heating & Cooling
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Air Conditioning broken - fan still works
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
Aug 31, 2017 | GE Heating & Cooling
I have a SSX140241A - 2 Ton 14 SEER R410A Goodman Air Conditioner Unit with a CAPF1824A6 - Goodman 1.5 to 2 Ton Cased Evaporator Coil. The coil came with a size 59 piston and the outside unit had a size 55...
No, it simply has to do with the fact that the conditions are exceeding the innate capabilities of the unit. Need more refrigerant and larger condenser and evaporator. Basically, a bigger, more powerful unit for the conditions encountered.
Sep 22, 2017 | Heating & Cooling
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
May 17, 2009 | Heating & Cooling
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Air conditioning unit not cooling
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
